  #1701
Old 10-03-2022, 08:27 PM
OldRedFord's Avatar
Kibble King
Went to Home Depot and got a little bit more wiring supplies.
Ten sticks of 1/2" emt
5 pack of 1/2 emt set screw couplings
5 pack of 1/2 emt set screw connectors
500 foot roll of 12 awg red thhn wire
Bag of 1/2" emt straps
Set me back almost $220
That should not cost that much but I gotta have it.
Tim
  #1702
Old 10-31-2022, 06:42 PM
OldRedFord's Avatar
Kibble King
Time for another update
Wiring on the shop side is now about 95% complete. Need to add a few extension rings to a few junction boxes just to make sure I have enough room for wire fill.
Have about 20 feet of conduit to run to a switch box by the walk door. Then wire the meter base and two 200 amp exterior disconnects and into the two 200 amp panels inside (which are the Square D QO panels involved in a recall) I thought I was buying good shit.
Feeder and conduit for panel in living space I'm holding off on until I'm sure my dividing wall framing passes.
Living space is wired except for feeder for ductless mini split system. Trying to figure out how to mount a exterior light and outlet for my back porch to the tin. Maybe metal roofing screws through the tin into a 2x4 or 2x6 block and surface mount the fixture and outlet?
Been cleaning. It's gotten out of hand in here and honestly I'm embarrassed.
ID:	166084   Click image for larger version
ID:	166085   Click image for larger version
ID:	166086   Click image for larger version
Tim
  #1703
Old 11-04-2022, 07:57 PM
OldRedFord's Avatar
Kibble King
Going to be doing some logging behind the shop in preparation for the septic install. Figured I'd slide the sawmill carriage inside to a safe spot.
Septic install looks like it will run me about $6000
Tim
  #1704
Old 11-04-2022, 08:31 PM
astronut's Avatar
astronut astronut is online now
Your building is filling up fairly quick isn't it?
Still got the shovel!
Lincoln Weld Pak 100
Giant Tech Arc 200
Miller Roughneck2E
  #1705
Old 11-04-2022, 10:06 PM
OldRedFord's Avatar
Kibble King
Feels like it but no. I've got a fair amount of shelves and cabinets and benches to bring in. I do feel like I've got a good layout for the machines and benches in mind. I will say I feel like I have a fully equipped shop already. Then if course the sawmill stuff will all be stored in the sawmill shed in an attached minimum 8x12 room.
I think I can still fit one more lathe and a boring mill
Tim
  #1706
Old 11-05-2022, 02:40 AM
Do I have a life?
I would make room for a plasma table...
HF 80 lunchbox w/tig
  #1707
Old 11-15-2022, 10:34 PM
OldRedFord's Avatar
Kibble King
A while back I filled out some stuff regarding the Square D QO panels recall. Monday Square D sent out an electrician to check the panels and all is well. While there the election noticed my conduit work and was impressed and asked if I worked in the field. Told him no. He was more impressed. So I feel better about my conduit work.
Have a tentative date of December 12th for my septic system installation.
Tim
  #1708
Old 11-15-2022, 10:59 PM
Are you going to get all inspections done before you have to give anymore silver to Caesar ? i.e. the damn building permit people
  #1709
Old 11-16-2022, 10:16 AM
+1
Once you get the local bureaucrat to sign off on inspections, you can continue to add circuits and plumbing and what they don't know doesn't hurt you.
  #1710
Old 11-17-2022, 11:48 AM
OldRedFord's Avatar
Kibble King
Yes. I'm getting a rough in inspection done soon Then I can take as long as I want.
Tim
