![]() Using a mixed blend of cast off parts, we are installing a disc brake on the outlet of the second transmission, in front of the u-joint on the outlet yoke. The disc brake caliper is off a 1983 Chevy Chevette, using it pads, the master cylinder is a hydraulic clutch unit off of a 1974 Datsun sedan, the disc is one I machined out of a piece of certified 3/8” boiler plate. I machine the plate into a 9.75” OD x 2.50” ID disc, machined a step in the yoke shaft, pressed the disc onto the yoke and welded it on. I chucked it up it the lathe and had extremely minimal runout. Norm installed the yoke/disc assembly on the backhoe, ran the engine and said he could see no runout. Tonight I machine the caliper bracket to gain a slight bit if clearance and threaded the mounting holes to 12 mm x 1.75 mm, for the mounting bolts. Today we took a few measurements, to start on the caliper support bracket, V1.0. Here is a picture of the disc installed on the transmission yoke
jack Last edited by platypus20; 06-07-2023 at 08:00 PM. |
Sounds like a fun project
Drawing by Smartdraw |
It sounds like it should work. Thanks for sharing the progress.
That's awesome.
Scott |
Sounds like a great doodle bug project.
We MUST see pictures of this creation...
Agreed.
What's the second shaft in the foreground for? |
some brake calipers had an emergency brake cable built in,having a parking brake may be handy.
Ford pickups and Nissan Xterras both run a combination disc brake and drum E-brake rear rotor assembly. It looks like you and Norm are well on your way with this setup. Just something to file away for down the road.
