Old 03-02-2013, 04:33 PM
Hummve Hummve is offline
Default Starting an 80 gallon smoker build...
I am starting smoker build hoping some here with experience can help with some technical questions that may come up.
First question involves the smoke/fire box ratio the tank is 80 gallons and the firebox I have is 20 which is only a 25% rather than the recommended 30% just wondering if this could give me issues if I will have to load the firebox more often or if it should be fine?
It is going to be a reverse flow design and when I'm done I'm going to mount it onto a small trailer. Thanks for looking and fit your feedback.
Old 03-02-2013, 05:44 PM
LW Hiway's Avatar
LW Hiway LW Hiway is offline
Lord of the Minions
This is so typical of me looking at a thread. For the life of me I cannot get any farther into the thread that just looking at the compressor and motor.
To be honest, I know nothing about smokers past the info I get from a book on the subject and that is for larger structures.
BUT, there are some good folk here that will chime in directly on your thread.
Old 03-02-2013, 05:54 PM
4-13-1949 to 5-21-2023
A friend of mine back in WA had a 100 gallon smoker and only had a 15 gallon smoke box. It worked fine for him. I made some fine jerky in his smoker.
LET'S GO BRANDON!!!!
B biggest
I idot
D democrats
E ever
N nominated
Old 03-02-2013, 07:32 PM
allessence's Avatar
Gadget Girl
I can't add anything either..
But I do really like smoked Salmon..
_________________
Jennifer
My google+ page
DoALL 36"
Old 03-02-2013, 07:47 PM
Ok good well I will go with it. Unless the inside is of the 20 tank is to rusted, there is some stuff rattling around inside :-/. I got lucky on the 80 gallon compressor the pump is actually in working order but the motor is shot. Picked it up at the metal recycling place for 100 buck$
Old 03-03-2013, 12:28 AM
Gadgeteer's Avatar
What is a "metal recycling place"?
Old 03-03-2013, 12:50 AM
getatorch's Avatar
getatorch getatorch is offline
Tuned-Up Big Builder
Go to "The Smokering.com" They have a calculator that is very neat. It works well I know. Actually I went a little larger on firebox and air flow areas because wtih adjustable air inlets etc. I can now cut down flow if need easier than getting out the torch after the fact to make something bigger.
"Freaking" is what you feel when things go wrong. The other word really refers to what happens when things go right... That one is only bad if it's against our will".
Old 03-03-2013, 01:00 AM
getatorch's Avatar
Here ya' go. http://feldoncentral.com/bbqcalculator2.html Don't go too small with a fire box or you will never be able to build enough heat to bake out stuff after you smoke it. The reverse flow method is well worth The while. Mine works great.
Old 03-03-2013, 08:41 AM
1-800miner 1-800miner is offline
When the cavemen invented meat smoking,they had a strict formula of 70/30.
If it varies you might be changing all of history as we know it.
Old 03-03-2013, 04:15 PM
I did use the calculator as mentioned. Fire box tank is 14x30 and it is a little older one fairly heavy and thick I think it should handle the heat ok. I do have a question about the stack how far should the stack penetrate the smoke chamber? I have built a smoker out of a 250 gallon propane tank knowing nothing about smokers for the most part and little guidance from the customer. I will dig up some photos and throw them up soon.
But on that one he had me float the stacks about 2" above the main rack which was positioned almost center of tank. Also the calculator shows an 18 inch stack I assume that is the exposed portion.
