Old 02-19-2014, 03:06 PM
prospero bastianelli prospero bastianelli is offline
Exclamation gantry cranes and cranes to place 2 tonne craft on machine tools
Hi my name is Prosper just rings are Brescia Italian for my mechanical Lab I is a small gantry crane 3-metre high 3 meters wide by 1.5 ft wide 2 ton capacity with manual chain hoist, according to my calculations I should use an IPE beam from 160/180 for the crossbar and a HEA 120 for the uprights or 100x100x4 mm box for 4 feet high-flow wheelsI put above, the lathe as crane, you could give me any tips or info thanks bye prospero Baby from brescia to the next
Name:	telaio palanco a portale mobile.jpg
ID:	113479   Click image for larger version
ID:	113480   Click image for larger version
ID:	113481   Click image for larger version
Old 02-19-2014, 05:21 PM
Here is some links that may help.
http://www.wallacecranes.com/thrftste_fixed.htm
http://www.shopfloortalk.com/forums/...ead.php?t=6821
http://www.shopfloortalk.com/forums/...ad.php?t=22999
http://www.beacontechnology.com/PDF/Gantry_Cranes.pdf
Old 02-19-2014, 07:22 PM
Cavalry's Avatar
Cavalry Cavalry is offline
Below Wholesale
Here is mine
http://www.shopfloortalk.com/forums/...ighlight=crane
Old 02-19-2014, 08:08 PM
DrBob's Avatar
DrBob DrBob is offline
I fear I'll do some damage one fine day
Default L'antenna Della Radio
Ciao Prospero. Non posso fare con il vostro progetto, my mi interessa l'antenna della radio e la torre nella terza foto. Sei un radeioamatore?
DrBob K2SK
Ciao Prospero. I cant help with your project but I am interested in the radio antenna and tower in the third picture. Are you an amateur radio operator?
DrBob K2SK
Old 02-19-2014, 09:21 PM
kiwi's Avatar
kiwi kiwi is offline
Bob,
Are you Italian?
Nick
Old 02-19-2014, 09:36 PM
Our Italian friend is speaking metric so 2 tonnes is 2000 kg
or 4416 pounds or roughly 2.5 tons, short.
Old 02-20-2014, 09:53 AM
Exclamation gru a portale per tornio parallelo
grazie signori utenti per le Vostre utili informazioni ne faro tesoro, comunque non sono redio amatore, vorrei altre informazioni che sistema usate per spostare i macchinari pesanti tipo: palanchini leve binde crick paranchi gru o altro: Confused: grazie ciao se avete altre informazioni vi prego di propormele grazie ciao
ID:	113496   Click image for larger version
Name:	gru portale.jpg
panta rei
Old 05-19-2014, 08:33 AM
Default progetto con misure
allego progetto con misure se qualche utente avesse altri suggerimenti o foto o altro lo prego di intervenire grazie ancora per il tempo e la pazienza
ID:	115700   Click image for larger version
ID:	115701   Click image for larger version
Name:	gru a catena.jpg
panta rei
Old 05-19-2014, 08:39 AM
weldor2005's Avatar
Perpetuus Discipulus de Vita
My brain hurts Best of Luck!
David
Finch Fabrication
My YouTube Channel
Old 05-19-2014, 08:48 AM
Stop drawing...and start welding....
good to see you posting again.
