Old 12-23-2009, 08:40 PM
JWBIRONWORKS's Avatar
JWBIRONWORKS JWBIRONWORKS is offline
Default Old Miller engine driven welder
I bought an older Miller welder today. The front panel is faded real bad. I can read the 200 amp and 65% duty cycle but that's about it. It has a single cylinder Tecumseh engine with electric start and 1 110 outlet on the front panel. Does anyone know if and where the serial # maybe stamped on the generator. It smokes when it first starts but clears up after it warms up and seems to weld smooth. I checked the Miller site and unless you have the serial # it only gives you the latest version of the manual. Any help would be appreciated.
John
ID:	54518   Click image for larger version
ID:	54519   Click image for larger version
ID:	54520   Click image for larger version
ID:	54521   Click image for larger version
Old 12-23-2009, 10:13 PM
Close to a Blue Star 2, 2E
Old 12-23-2009, 11:02 PM
Tailshaft56
Guest
Posts: n/a
I'll lay a Dollar to a donut you can still get a new overlay for the panel if you want to restore it.
Old 12-23-2009, 11:10 PM
engineman56's Avatar
engineman56 engineman56 is offline
Nutbuster
On the Miller welders That I repair at work the serial # is on that front plate like pic 3 shows. It should be near the on/off switch or near that Duplex outlet. Thats where they usually are on my Miller machines. However those welders are not engine driven. They're 3 Phase 230v. Kevin
It's a Normal Thing Around Here I Don't Have no Money!! Just Junk. The Problem With Most People Is They Can't Recognise A Good Piece Of Junk.
"Great spirits have always encountered violent opposition from mediocre minds."- Albert Einstien
I'm mostly worthless! You'll see.
Old 12-24-2009, 12:36 AM
seagiant's Avatar
seagiant seagiant is offline
Hi,
WOW! Sweet! You could throw that in the back of you"re pick-up and make some money!
Old 12-24-2009, 01:02 AM
Looks like the first 2 characters in the red box say "S/N" so that's probably where your serial number used to be.
Send Miller your pictures; I bet they can identify it.
ID:	54550   Click image for larger version
Old 12-24-2009, 07:00 AM
GWiz,
You maybe right it appears to be a bluestar. Thanks for the info
Seagiant,
I couldn't sell ice water in hell and make money.....But I try
Thanks everyone for the replies
john
