Rest In Peace Cutter
Old 10-24-2012, 04:38 PM
Randyjaco's Avatar
Default MIG gun for an L-TEC 225?
The L-TEC 225 saga continues. The folks that told me that they had a liner to fit my MT-200 gun now say that they can't get it. Soooo, it looks like it is time for a new gun that I can get parts for when I need them. Any recommendations on a good MIG gun that will fit my L-TEC that won't break the bank?
Thanks Randy
Old 10-24-2012, 05:45 PM
monckywrench's Avatar
trust but verify
Pull out liner, post pic with dimensions of brass fitting at end of liner.
Tried online? You can also email dimensioned pic to vendors.
Old 10-24-2012, 06:38 PM
Randyjaco's Avatar
I tried several places online with no success. I have had more than one vendor tell me they could get it, only to find out they couldn't.
Here is a picture. This one runs .035- .045' wire. The hole diameter in the brass is .062"
Randy
Old 10-24-2012, 06:51 PM
Scott V's Avatar
Scott V Scott V is offline
http://www.ebay.com/itm/Esab-17717-0...item3cc89477d6
.030 one, but they have a few others.
This one is 12ft, but .052. Probably get you by?
http://www.ebay.com/itm/Esab-17719-0...item3cc894824d
Old 10-24-2012, 08:34 PM
trust but verify
That's an interesting liner.
I've cut long liners to make liners for guns which didn't have one handy, but that odd o-ring and ferrule setup is a challenge. If you could machine a new fitting out of brass with a small bit of extra tube for support, you could shove a cutoff liner (the plastic-coated end) into it snugly and be good to go.
Old 10-25-2012, 08:28 PM
Randyjaco's Avatar
Thanks Scott,
I started looking farther into EBay and I found another 15' liner for my gun that I can cut down to fit, so I bought it. Hopefully it will work.
Thank you too Monky
Randy
Old 10-26-2012, 04:40 AM
J bar J's Avatar
J bar J J bar J is offline
The guy I use lives out your way in Clear Lake. Might be worth a call. PM me if you want to try I will give you a number. May be too late now but a good contact just the same.Mike.
Most people are about as happy as they make up their minds to be!
Abraham Lincoln
If your scared say your scared!!! :eek
That's Harder Than Chinese Arithmetic!!
Old 10-26-2012, 11:52 AM
trust but verify
Always have a couple spare liners. They never fail at a convenient time.
Old 10-26-2012, 11:52 PM
Scott V's Avatar
Originally Posted by Randyjaco View Post
Thanks Scott,
Thank you too Monky
Randy
Randy,
Those MT-200 guns are really tough units. The micro switch trigger is a pain, but the guns/ cables are really good.You should have no issues cutting it down. Many liners come real long, and you have to trim them anyway. The 15 ft MT-200 gun I had on my first Esab Migmaster 250, was the only gun I ever used that would feed .023 wire perfect. That was using the factory .035-.045 liner. I don't recommend though..
Old 10-27-2012, 12:42 PM
trust but verify
Remember when cutting gun liners to use a method which doesn't leave an internal burr or it will grab the wire and cause birdnesting.
