Old 11-12-2018, 04:20 PM
flametamer's Avatar
flametamer flametamer is offline
Send a message via Yahoo to flametamer
Default Broken Bolt Welding Rod
What's the name of the high$$ welding rod used to remove broken bolts?
Dt
Sero Sed Serio
Old 11-12-2018, 04:37 PM
Was it this one?
Originally Posted by precisionworks View Post
Messer MG600 is the only rod I've ever used that consistently removes bolts, studs, taps, etc. Even if they're broken way down in the hole, MG600 will get them out.
That angle can't be as bad as welding out broken exhaust manifold bolts from underneath the car/truck I don't do that often, and normally charge double for removal - that covers the burns & supplies used. But it really isn't that hard, no more difficult than any other overhead SMAW weld.
Old 11-12-2018, 07:37 PM
Here you go https://shop.rhdaveywelding.co.uk/Sy...Tractalloy.PDF
Old 11-12-2018, 09:08 PM
platypus20's Avatar
Boiler God
I’ve always used the MG 600
jack
Old 11-13-2018, 04:58 AM
Are yall talking burning out the bolt with the rod ?
with cast manifolds and stubborn broken head bolts in cast heads I've always used a torch and blown em out with out damage to the threads.... the chase the threads with a tap easy peasy…..learned that back in high school....
Old 11-13-2018, 06:24 AM
No, I think they are talking about using a special rod that can build up a broken off bolt enough to either weld a nut on or something to get a pair of vice grips on to turn out. The rod they are talking about can be pushed down on top of the bolt even if it is broke and inch or two below the surface of the part. It has a hard flux that protects the threads from the weld filler, and is super strong.
I usually just tig weld up a tit to be able to get a pair of vice grips on it. Just did this Friday on an aluminum hydraulic motor part. A 10/32 screw broke off flush with the casting and it took about five times of welding a tit on, but it finally came out. I thought the threads were toast, but was able to just put in a replacement screw. Boss was happy. I was working the screw back in forth while watching the lathe make chips on another job.
A lot of times, the heat of welding helps break the screw loose if rusted in too. Also, I will melt candle wax around the screw threads while hot and that usually helps to remove the screw too. Great tips I learned from this forum.
Old 11-13-2018, 07:48 AM
flametamer's Avatar
MG 600 That's it. Thanks
Dt
Sero Sed Serio
Old 11-13-2018, 10:05 AM
X2 on the candle wax...…..definitely helps with screwing So do handcuffs, but sometimes she loses the key
http://www.farmersamm.com/
Old 11-13-2018, 12:00 PM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
If the bolt is of a large enough diameter, I have drilled almost through the bolt, than welded the hole shut to shrink the od of the bolt, works 90% of the time. The other 10% of the time I can see how that rod would be a lifesaver.
I will have to find a supplier of the Messer rod. A couple pounds on hand might be agood idea.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 12-30-2018, 11:33 PM
I finely found a place that sells this rod locally, and they will sell it in assorted rod size and is 35.00 a pound I don't know if it is comparable priced to others places but it sounds fair to me considering LWS's wont order it or like to assrasp a guy on the cost of shipping added one place was 43 a pound w/5 pound min. ordr and 38 bucks shipping WTFudge…..
any way question is this rod store well and is it worth keeping on hand
being I use all sorts of methods of taking out broken bolts even use the left handed drill bits but I on occasion come across that stubborn bolt that refuses to come lose or out but by then I've done screwed it all up anyway
