Old 01-15-2021, 08:23 PM
Default Seen one of these before??
This looks interesting. But, I ain't buying this one without feedback/research.
https://www.qualityya.shop/products/...lic-floor-jack
Old 01-15-2021, 09:03 PM
Sounds like it would work well for a car. My truck curb weight is around 7,500 so not likely it would work for me.
LET'S GO BRANDON!!!!
B biggest
I idot
D democrats
E ever
N nominated
Old 01-15-2021, 09:14 PM
multiply your curb weight by one 1/4 figuring on using it in emergencies to change a flat easily within it's capacity.
Old 01-15-2021, 09:30 PM
It said 3 ton capacity, so it should lift one wheel without a problem Chris.
Being 12v, from a cigarette lighter, I bet it is slower than a bottle jack.
Old 01-16-2021, 10:15 AM
Not only would I not buy one, I wouldn't even click the chinese link, much less give them any payment information.
Old 01-16-2021, 11:05 AM
Attachment 159166
If it cannot lift the whole front end I cannot rotate tires easily. Can use jack stands, but I can do it that way now.
B biggest
I idot
D democrats
E ever
N nominated
Old 01-16-2021, 12:34 PM
I wasn't going to buy one. But, I'll bet there will be better ones out there in short order.
Old 01-16-2021, 01:11 PM
Norm W's Avatar
Norm W Norm W is offline
I suspect there will be people that buy one and have no clue how to use it.
Old 01-17-2021, 05:55 PM
Do I have a life?
Looks like a "w i s h" item... You'll need to carry a level so you can make sure it is on perfectly level ground otherwise I'd say it looks tippy as hell, especially extended!
PS: I was trying to figure out what that other thing was with the handle, looks like an abbreviated leaf-blower. It is actually an impact wrench...
HF 80 lunchbox w/tig
Old 01-17-2021, 06:56 PM
Tim KS's Avatar
Tim KS Tim KS is offline
Master Procrastinator
I'm not a tire guy, but MY tire guy says to rotate radials from front to back and never side to side. What is correct?
