Old 08-06-2004, 03:34 PM
morpheus's Avatar
morpheus morpheus is offline
Default What is this guy using ?
Is this the longest cutting torch I've ever seen or something else ?
Jack's Place - 4x4's, Tools, Humor, Bungi Jumping and more ....
Old 08-06-2004, 03:45 PM
wolfgangwelding's Avatar
wolfgangwelding wolfgangwelding is offline
Cant see the pic very well but looks like arc gougeing with with presureised air.
no you cant fix it with a hot pass
Old 08-06-2004, 03:46 PM
Mike W Mike W is offline
That is an oxygen lance. If I remember correctly, you start the cut with a regular torch and then turn on the lance which is just a piece of pipe with oxygen coming out.
Old 08-06-2004, 07:11 PM
ralenr ralenr is offline
Definitly an oxygen lance. You can do pretty much the same thing with an oxy/acetelyne torch. Once the you get the cut going all you need is oxygen. But not that large of course.
Allen
Old 08-07-2004, 05:07 AM
Ok I see, ive came acros talk of a oxygen lance before. Last time was when the twin towers fell we where watching workers cutting large I beem with what looks like the same thing.
Old 08-09-2004, 12:15 AM
revpol revpol is offline
It's a oxy. lance. The pipe is packed with a substance (I've forgotten just what it is) to keep the fire going at the end of the pipe. The pipe and all melts as you use it. The pipe comes in sections that can connect together. The ones I've used varied from about 3ft. to 20ft. long. This thing cuts through just about anything, once I even cut through some fire brick in the ash hopper of a boiler to blow a hole out the steel casing of the other side. revpol
Old 08-09-2004, 07:34 AM
I think they are packed with magnesium but not sure.
Old 08-09-2004, 08:55 AM
Brainfarth Brainfarth is offline
At the steel mill they had a few torches that were about 10' long running on Natural gas to cut the billits going to the cooling bed when the automated torches would screw up.
ahhh yup.
Old 08-09-2004, 09:28 AM
morpheus's Avatar
Natural Gas ? I wouldn't think that would get hot enough ...
Old 08-09-2004, 10:33 AM
Franz Franz is offline
Banned
Lance, burning bar, whatever you want to call it is a piece of ½ iron pipe with iron wires filling the pipe, somewhat loosely.
The iron is the fuel, just as molten iron is the fuel when you are cutting with a torch.
Generally, you don't want to be hanging onto one that is only 10 feet long.
Natural gas cutting is accomplished by compressing the NG. About 20 years back there was an outfit selling the units that compressed the gas, around here, on the basis the price of acetelene was going thru the roof, and you could ammortise the investment in the compressor and storage in 5 years. I know of 1 unit that is in place. Compressed NG burns about like propane.
