Old 06-12-2011, 10:14 AM
Vern2's Avatar
Vern2 Vern2 is offline
Default Building Lathe magnetic strip and tool caddy
Been tossing this around, will try some bends today in 18 gage mild steel. The two brackets will be 1" x 3/16" bar stock. I want to get the magnetic strip above the splash board. Don't know how this will work cutting the holes. My arm is not steady enough to make the plasma holes look good. So picked up a hydraulic punch set.
ID:	77961   Click image for larger version
ID:	77962   Click image for larger version
ID:	77963   Click image for larger version
Vern
http://www.enichesoftware.com
Old 06-12-2011, 10:55 AM
Fla Jim's Avatar
Fla Jim Fla Jim is offline
Harbor Freight Backslider
Vern.
The only problem, is that tools on a magnetic strip become magnetized!!
They tend to collect a bunch of chips, and swarth.
Ask me how I know.
Jim the Shop Rat
From Jim’s Magic Garage®
Old 06-12-2011, 11:28 AM
moe1942's Avatar
moe1942 moe1942 is offline
Voice of Experience
Nice chip collector...
Old 06-12-2011, 11:47 AM
Vern2's Avatar
Hay! Not a chip collector. You pull the tools off and lift the shop towel, chips fall to the drip pan, all clean. Plus my chips are so big they don't fly that far. Plus I'm raising it about 12" with brackets, with tool caddy and remember that china stuff don't have much steel in it. Does that take care of the jokes a little?
Vern
Old 06-12-2011, 06:16 PM
Cavalry's Avatar
Cavalry Cavalry is offline
Below Wholesale
i did a similar thing on my Sheldon using a kitchen knife magnetic rack. Its been 3 or so years an no problems with magnetism from the things stuck to it (chuck and adjusting wrenches)
Old 06-12-2011, 06:42 PM
MarkBall2's Avatar
I didn't like the idea of magnetic tools, plus some don't have enough metal on them to use a magnet to hold it. So I built this...
I've since added some more pegs to it & an angle iron bracket to hold the tail stock centers, drill chucks & drill chuck wrenches.
Mark
Hobart Handler 175
Chicago Electric 165A DC TIG
Oxy/Acetylene set
Hand/Power tools
Clark 4x6 Bandsaw
Harbor Freight Tubing Roller
Craftsman 12 x 36 lathe
Papa Lion's Gate Build
Old 06-12-2011, 08:17 PM
Vern2's Avatar
Disclaimer: Do not try this at home! Call an AC guy.
I like it MarkBall2. Looks like you do Condenser work with the gages hanging on the back wall.
I was looking at this model.
Manifold
And these hoses. Was thinking I'd like the 36" ones.
Hoses
I like this vac pump.
1.5 cfm - 2 stage
Because I'm not in any way an AC guy. This meter will tell you the exact vacuum you've pulled down to. A must if your not sure, you've pulled enough vacuum. The instructions will ask you, to pull an exact amount and you have no idea if having the vacuum pump on for 8 hours was enough. digital gauge An AC guy will run it for a few hours and call it good. He gets paid to screw up, you don't. The AC will work, but it just won't be right (cost you more money to run it)
Tubing cutter
There's also a few odds ends to get. Nylog Blue - Snot, 37 Degree Flare flange tool. Hopefully no Mapp Gas.
This is a total kit, freon is already loaded in condenser for you. They go up and down in price a lot. 6 months ago this one was around $1000. The 2 ton is only $300 more.
17,500 btu
I've done some reading on installing my own 1.5 or 2 ton mini split. I'm adding a 100 amp sub. so the air handler will be real close to that and the condenser will be on the other side of wall on concrete.
Don't cut the feed or return lines. Their close to the length needed to match the Freon load provided.
I'm using a 30" fan now it blows a lot of wind, at about 150 mph. It clears out the hot air in the shop right now. The neighbor across the street thinks a wind blow up and goes in the house.
Vern
Old 06-12-2011, 09:25 PM
MarkBall2's Avatar
Not house condensers, but my van. I have a slow leak & don't want to blow the seals on the compressor, so I just charge it a couple times a summer, then let it bleed down in the winter. I only need it about 9 months a year. This winter I'll change the hose, then give it a full charge.
Those are HF gauges. What I don't like about them is you have to disconnect the low pressure hose to charge the system. Higher dollar gauge sets, you charge through the gauge system. But these work ok for my needs.
Mark
Hobart Handler 175
Oxy/Acetylene set
Hand/Power tools
Clark 4x6 Bandsaw
Old 06-12-2011, 09:53 PM
Vern2's Avatar
Like acting like a machinist, I am not one, but I bought a lot of hats. The hats fool a few people, some of the time...
I would like you to point me in a direction to get the ones that can be charged through the manifold. How do you know or what do you look for?
Thanks,
Vern
Old 06-12-2011, 10:04 PM
MarkBall2's Avatar
The ones that charge through the manifold are usually high dollar manifolds sold to auto repair shops. Don't know if they are Snap-On, Matco or some other "pro" tool source, but most of the auto repair shops have this kind. Primarily because the freon they obtain is the size of a 20# propane bottle.
I'm sure they can be found, I don't know where to look without asking the shops. I would bet they are way north of a hundred dollar bill.
Mark
Hobart Handler 175
Oxy/Acetylene set
Hand/Power tools
Clark 4x6 Bandsaw
