Old 04-30-2019, 01:49 PM
OldRedFord's Avatar
Kibble King
I ended up getting a 1 1/2 piece of 12L14. It was about $60 shipped from Online Metals for a 48" stick.
Two intended projects for it are a new screw for a Palmgren 6" mill vise I got cheap and a new cross slide screw for the $100 Monarch.
Tim
Old 04-30-2019, 01:54 PM
That is awful soft steel for screws.
Old 04-30-2019, 06:07 PM
JBFab JBFab is offline
It'll machine beautifully, but yea quite soft for a vise screw.
Sent from my SM-N960U using ShopFloorTalk mobile app
Old 04-30-2019, 07:02 PM
OldRedFord's Avatar
Kibble King
What would be the right steel to use?
Tim
Old 04-30-2019, 11:16 PM
I would look at 4130 or 4140 annealed or half hard, sometimes called pre-hard.
Old 05-01-2019, 05:24 AM
There are different acme threaded rods available too, cut to length, machine the ends as required and good to go.
Old 05-01-2019, 09:33 AM
OldRedFord's Avatar
Kibble King
The acme screw has a 1 1/4 " x 3/8 ring made into it where it enters the vise body or I'd have just gotten some acme screw.
Tim
Old 05-01-2019, 09:40 AM
You can weld up a ring or boss on the thread and machine to size. I would go slow and keep the HAZ to a minimum, and you got your screw done.
Or, make that boss out full length to be part of the piece where the sliding handle bar goes through. Bore a hole and machine the end of the acme to fit, and silver solder it in.
Aaron Neville
Old 05-01-2019, 09:54 AM
I wold do a press fit into the 1 1/4". After the handle is installed there would it be a problem even if the fit failed.
Old 05-01-2019, 10:45 AM
OldRedFord's Avatar
Kibble King
I'm a bit bummed. Can't get 12l14 or 4140 locally without going to Atlanta.
Tim
