Old 04-13-2019, 02:45 PM
Default When You Absolutely Have To Use HSS
As many of you know I'm not a fan of high speed steel tools in today's world--I avoid it as much as I can for practical reasons. However, there are times when nothing else will really work and you have no choice but to grind a tool. I found this video by Adam Booth which shows such a time. Given the space available and the clearances involved I can't think of an insert style tool that would do the job.
I did something like this--on a smaller scale--about 5-6 years ago and, of course, no video or pictures. If I remember correctly it took about 45 minutes to get the tool right--that's one of the downsides to not grinding a lot of HSS--it takes you longer to get it right. Still, even I can do it if need be.
The video is longer but grinding the tool and using it takes up the first 10 minutes or so...
https://www.youtube.com/watch?v=thnT0xZUXX8
Old 04-13-2019, 02:57 PM
I’ve made similar tools for grooving and cutting internal threads etc. HSS or a piece of carbide silver soldered to a mild steel holder both work.
For ‘fussy’ sizes and shapes, I usually go to a surface grinder and grind them there now. Rough it out on a mill or bench grinder, finish the profile on the surface grinder, and done. A sine vise makes it easy to setup the relief and clearance angles.
Old 04-14-2019, 12:47 AM
clive's Avatar
clive clive is offline
Being retired I can use HSS and not worry about cost, I quite like using it although of course I use inserts but being on a fixed income the cost of HSS figures high in my choices. I use it threading a lot as I like to thread in reverse away from the chuck.
It's So Easy
Old 04-14-2019, 08:51 AM
I liked how FAST he adjusted the 4 jaw to center that bore . :-)
...lew...
Old 04-14-2019, 09:46 AM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Adam, has a lot of practice at adjusting an independent 4 jaw.
HSS, has it's uses.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 04-28-2019, 06:32 AM
jatt jatt is offline
On interrupted cuts for sure.
Even on hard stuff, until I get past the worst bits. Just have to resharpen more often and away we go again.
