  #61
Old 05-09-2019, 07:09 PM
A lot of folks claim the rubber box liner materials help to deaden sound. Not sure how they are fir weight, or for the rules you need to play within.
  #62
Old 05-09-2019, 07:13 PM
Originally Posted by RED caddy View Post
PS The name "one trick pony" on a red white and blue, stars and stripes base , is in first place.
Midnight black with a green and blue metallic base with a string of mustang ponies down both sides ghosting towards the back form a solid one to the front
and call it... "Sound of Thunder" or "The Stage Coach" Or "Pinto Express"
I use to have a 67 Ford Cougar with two-tone paint split from bottom corner of the front door to the top of the rear tail midnight metallic black and midnight metallic blue then split with a silver metallic lightning bolt and was called the "Light Show" ran an LC big block 429 other people named it I didn't but it stuck.
  #63
Old 05-09-2019, 10:11 PM
Any ideas on how to sound/heat insulate the fire wall?
A long time ago, I used some bulkhead material that was 2- .045? sheets of aluminum bonded to an aluminum honeycomb core, very light/strong and durable, just can't remember what it was called or where it was made, anybody remember it?
OK that's enough for now, pencils up. Begin
RED
Honeycomb Core Sandwich Panels
They sell it here and on ebay
  #64
Old 05-09-2019, 10:36 PM
TEK's Avatar
TEK TEK is offline
Al righty then, update time again.
What about "One Trick Colt" with some 1911 graphics thrown in ?
-----DozerDan
  #65
Old 05-10-2019, 09:43 AM
Great material for sound deadening but not flexible, so have to piece it in for contoured areas.
Woodrow Wilson
  #66
Old 05-10-2019, 10:00 AM
platypus20 platypus20 is online now
Red,
I’ve seen some of those aluminum/honeycomb panels, very stiff and incredibly lite, I’m guessing not exactly cheap either.
I can’t help you out firewall wise, unless a piece of 5/8” boiler plate would help??
There is a guy here in Syracuse, who has a Pinto wagon, tube frame, small tubs, Ford 9” and a Ford/Yamaha based, seriously modified Taurus SHO engine with a Lenco. Its a sleeper, red body, one blue fender, yellow door, steel wheels, very fast.
He also has a Chevy El Camino, with Buick Grand National front sheet metal, with a twin turbo Buick V6
  #67
Old 05-10-2019, 10:42 AM
RED caddy's Avatar
Da Chief
Yea, I did a little shopping, the cheapest I found was north of $60.00 a square foot. (the last time I used any, it was supplied by uncle surgar.) It's eggzackery the right stuff, just way too pricey for me. (this ain't gonna be a 100 K race toy, total budget is way south of 10 K)
The best I can come up with is 14 Ga. steel, covered by duct board and then with 18 Ga. stainless sheet. Only the part right under the windshield pinch weld will need some massaging with my planishing hammer. The rest of it is flat.
I'll try to add a picture album today. (having a bit of crap getting them from my phone to the desktop)
Jack, that's my target pack, very fast, but still streetable. There is an old, 40's Ford PU, tube frame, with a 427 and a V drive , all hiding under a toneau cover, rollin on fatties, runs high 8's. He's on my hit list...
SWMBO suggested a flying, pinto painted, unicorn graphic for the rear quarter, that might stick. just have to find an artsy type to sketch it.
RED
  #68
Old 05-10-2019, 11:09 AM
RED caddy's Avatar
Da Chief
Finally, some pictures.
Name:	prostock pinto 3.jpg
ID:	150683   Click image for larger version
Name:	prostock pinto 2.jpg
ID:	150684   Click image for larger version
Name:	prostock pinto 1.jpg
ID:	150685   Click image for larger version
ID:	150686   Click image for larger version
  #69
Old 05-10-2019, 11:57 AM
RED caddy's Avatar
Da Chief
more pic's to follow
Name:	pinto roots 1.jpg
ID:	150689   Click image for larger version
Name:	pinto roots 2.jpg
ID:	150690   Click image for larger version
Name:	pino front.jpg
ID:	150691   Click image for larger version
Name:	pinto roots 8.jpg
  #70
Old 05-21-2019, 06:46 PM
RED caddy's Avatar
Da Chief
Today, I finally got to speak directly with Teri, at Showcars direct. There are 2 different mold's for the Pinto nose. They differ only in length. One stops at the same point as the stock hood, the other goes back to the top and front door edge and stops just short of the windshield. Teri is pretty sure they have both in house. Waiting on a return email and pictures.
As you can see from the last pic's, I will need the longer one and will rebuild the windshield apron to accommodate the windshield wipers and make the body air/smoke tight from the firewall back.
Then build the tree to allow the whole piece to slide forward about 4 or 5 inches, then pivot to the front, for easy engine access. Will still need 2 or more people to remove and replace the front end, but should make every day maintenance and quick tune changes a breeze.
Considering fabbing up some inner fender wells to keep the road splash at bay, not sure if I will ever drive this beast in the rain though.
I finished the mid mount plate pattern, still looking for a 18" X 36" X 1/4 inch aluminum plate. (have jig saw, will travel) I will have to set the bare block and tranny in on new mounting tabs, before I fab the front motor mounts and rear trans mount crossbar and finalize the driveline angles.
All solid mount points might be a bit noisy for the street, but the large gain in chassis stiffness is worth it. That big, heavy, 4 bar third member will let me move the center of gravity at will and direct the torque to anyplace I want it.
Even with the short, coupe, wheelbase, a dead hook launch should be doable and 1.0 SEC. 60 foot time in reach...
OK, back to reality, still have MANY DAYS WORTH OF WELDING/GRINDING FABRICATING, AND REDGINEERING, TO GO.
Rollin, Rollin, Rollin,
RED
