i may wash out and refill,but... |
I have done lots of trivial crap jobs to save money, but not THAT trivial.
Let FAITH be bigger than your FEAR. ***** Pray like everything depends on God, and work like everything depends on you. ***** The world is changed by your example, not by your opinion. --St. Mother Teresa ***** In life it's important to know when to stop arguing with people and simply letting them be wrong. ***** Live like you are dying......because you are. |
The jury is out, it has sat on the floor for 3 days and is at 12.74 volts, when it would have gone dead before. I was talking to a guy about this and he said it is much more effective to use a stick welder at about 100 amps for 15 minute shots. Common sense safety needs to apply here or leave it alone.
Gerry You got freedom of speech, if you don't say too much. Aaron Neville. When a liberal screams racism, you can bet they were also born with white skin. Common sense is like deodorant. The people that need it most never use it. Joe Concha |
I've seen 2 Batteries explode over the years. The first that sticks with me was an old guy that worked for the township trying to help out a friend. When he tried to attach the jumper cables the entire top of the battery blew out sounded like a 30-06. He, got very lucky ended up with a chunk of the top of the battery in his thumb on the hand hooking up the jumpers. I'm ok with trying to revive lead/acid wet-cells. Trying to wake up Lithium battery packs is the shit that scares me.
The same applies to load testing. Some people pull a 500 amp load test, forget to spin the dial down to zero and then yank the clamps when the 15 second buzzer goes off. The whole exercise is make no sparks. Quote:
Bit of an update here. The 8D battery which would drop it 1 volt overnight is still holding 12.74 volts. I put it on the carbon pile load tester and wound it up to 500 amps. It held the voltage just above 10 volts for 15 seconds and the tester was radiating heat by then. And bounced up to 12.5v when I dropped the load off.
So this was sort of a success. I would have felt better if it had stayed up around 11.5 volts but I definitely knocked off some of the sulfate. Lithium battery...uh, well...hmm
About 21"x11"x10", ~125lbs, ~1500CCA--that's a biggun! Saved yourself $300+US!
Yes. Actually I was told by the recon guy it is 175lb. But you got me curious so I looked it up and it varies from 125 to 160lb. for flooded cells. I do not know why the difference is but it is heavy.
Especially when someone at CAT thought under the seat in a battery well was a good spot for 2 of those Bastards with rotten rope handles Don't remember what model anymore
