![]() I learned to weld in high school and I have done some stick, MIG, and TIG over the past 50 years. I always had access to high dollar welding rigs, but I am mostly a torch jockey. I own a few sets of Victor torches and regulators, but I have never owned an electric welder. I have modded cars and motorcycles with just a torch. But now I am keen to buy a quality TIG or multi-function welder, and there are a lot of choices. I have a 240vac 50 amp receptacle available, so no 3-phase or high power gear will work. And it’s unnecessary. I am just welding cars, and mostly light gage mild steel to 1/16 or 1/8. I may see a little 3/16” or 1/4” plate but I can make 3 passes if necessary. This welding only needs to please me. I also want to do some TIG brazing on 16ga cold rolled. Since I’m not trying to make money, the duty cycle is less important than it could be. At my age I’ll probably be ready to take a break before the welder is anyway . What I want most is advice on high quality pedals, torches, and switches. I need the sensitivity to weld thin gage more than anything. I don’t want to diddle around with janky gear. I have worked with a clunky pedal and it was torture. I want advice on the best stuff that isn’t unobtanium. |
Welcome Aboard!
![]() I'll post up some links to keep you busy for now... ![]() Foot pedals and other controls can be found at https://ssccontrols.com/ Miller now owns Weldcraft who makes quality torches. LINK CK Worldwide also makes quality torches and accessories--I'm running one of their #20 torches on my rig. LINK This link from Miller has a number of handy welding guides you can peruse and/or download. LINK PS: CK had this .pdf guide on their site...
TA Arcmaster 185 w/tig/stick kit MillerMatic 252 w/3rd gen 30A MM140 w/o AS, w/CO2 Hobart (Miller) 625 plasma Hobart 250ci plasma Victor O/A (always ready, but bored) TA 95 lunchbox w/tig 45ACP Black Talons for those stubborn jobs... Last edited by mccutter; 09-16-2021 at 06:26 PM. |
If you are going to every want to TIG aluminum you should look at a AC square
wave machine with High Frequency stabilization. If you will never weld aluminum a DC only machine will do you fine. https://www.millerwelds.com/equipmen...-welder-m00337 I like weldcraft consumables and have a ProFax pedal. Some members have some good reviews for HF Titanium series line of welders.
![]() ![]() ![]() ![]() ![]() Even if it WAS only $1600, I would have a problem because the torch is hard-wired in and not replaceable (ie: no water-cooled) unless you want to void the warranty by modifying the machine. ![]() I saw this at debay for $379 which I would never consider BUT I might throw a $50 bill at it if I saw it at an auction Div165. Would be the perfect opportunity to adapt a Dinse connector and "common" torch connection. Maybe... ![]() PS: even if you are only welding at say 125A and well within the duty cycle, with extended welding that 150A torch will start to get "warm" and uncomfortable to hold. ![]()
TA Arcmaster 185 w/tig/stick kit MillerMatic 252 w/3rd gen 30A MM140 w/o AS, w/CO2 Hobart (Miller) 625 plasma Hobart 250ci plasma Victor O/A (always ready, but bored) TA 95 lunchbox w/tig 45ACP Black Talons for those stubborn jobs... Last edited by mccutter; 09-17-2021 at 01:10 AM. |
A shop I sometimes work at on the side bought a Esab Rebal ( not exactly sure the model, but will do AC tig aluminum) multiprocess welder couple years ago. Unfortunately, right after I needed it for an aluminum handrail project I did for them.
They have been real happy with it. Owner told me last week that it would be all a typical home garage would ever need. Sent from my iPhone using Tapatalk
Not often that one tig welds at 125A though unless doing aluminum. If one is tigging steel at 125A, they may as well break out some wire or stick instead. Sent from my iPhone using Tapatalk |
I will add that Millers MSRP is high and generally you can find them for 20- 24% below MSRP at you LWS. Mine would discount them at 24.5%. So I did not have to call them for pricing. Accessories were a different discount and not as flat rate so I had to call for that. I am a fan of blue paint, but the red machines I have been told have a following. I have not welded with any of the HF welders but a few members have. Here is an option. Hopefully Jack chimes in. https://www.harborfreight.com/weldin...put-56254.html
Uhm.....Yeah....
It’s kind of strange that it’s difficult to find a used welder here and then all of a sudden six of them show up on craigslist.
Unfortunately they are all overpriced or too old and heavy for my taste. I could pick up a used Lincoln Idealarc 300 Tig for $1500 With a bottle cart and accessories.. Unfortunately I can’t pick it up. Period. It’s a freaking boat anchor! I’m going to need something a little more portable that I can roll from my garage out to my boat yard and back Without a towmotor. |
I really am not up on tig machines, but for welders in general right now if you are worried about size and features more than duty cycle, then an inverter type machine is the way to go.
I run lincoln welders in my shop. Dad had an old tombstone stick welder I learned on and they had lincoln welders in the lab when I was in college. I have had good luck with them. I know you're talking tig but my lincoln power mig 216 is a transformer machine, and my MP 210 is an inverter. The 210 has 3/4 the power and much lower duty cycle but I can carry it like a suitcase, where the 216 requires a loader, and the 210 has many more features/parameters to fine tune with. For the criteria you listed I would be shopping new small inverters and passing on the old industrial stuff even though they are familiar names.
Handcrafted Leather |
Tags |
tig |
