We had a member, Old Man, who removed a crapped motor from a Ranger and replaced it with a Honda twin. Do a search for his thread on this and that will tell you what he did to remove it. The shaft is tapered and the generator shaft is a female taper.
Gerry You got freedom of speech, if you don't say too much. Aaron Neville. When a liberal screams racism, you can bet they were also born with white skin. “The word ‘racism’ is like ketchup. It can be put on practically anything — and demanding evidence makes you a ‘racist’.” Thomas Sowell |
Welcome to the site.
likely there is a 12" or so long through bolt that holds the rotor to the engine that you need to remove first. there is also a type of puller some type of bolt to break the taper lock once you have removed the ~12" bolt.
Once you remove the bolt holding the rotor onto the engine shaft you should see a thread it the end of the rotor. a long threaded rod is used to jack the rotor off the tapered crankshaft.
I have found that later inexpensive units are not meant to be repaired and may not be threaded for removal. I have such a unit in for service. I tapped the rotor shaft and made a push bolt. it has been under about 100 ft lbs torque for a couple of weeks and gets a hit with a dead blow hammer every time I check it. At this point it is probably beyond salvage as I suspect that the rotor is either threaded on ( a tapered shaft with an external thread mated to a rotor with a matching taper and internal thread or was lock tited at the factory. Neither assembly method allows for easy field disassembly. The truth is that I can supply a new replacement generator for less than the cost of a repair to the windings. There are diodes mounted on the rotor and I suspect that they are the problem but they cannot be reached unless the rotor is removed.
Life beats the alternative hands down. |
Then visit the Briggs website and start the process of finding information that could help you. : https://www.briggsandstratton.com/na.../manuals.html#
Running away is the coward's way out of war. Appeasement is the coward's way into one. Biden & Harris is our enemies favorite candidates In time the right project will find the scrap pile, no need for the scrap pile to go out looking for a project. http://www.swiftvets.com/phpBB2/viewtopic.php?t=24981 http://tosettherecordstraight.com/index.php |
I have been thinking the same thing but due to a serious family issue have not been out to work on it. it is rather the last dich effort as it should generate about 10,000 psi
![]() I may get to it later today.
If it is locktited , permanent or whatever, at 300 degrees it turns to goo. A heat gun will work to soften that if they used it.
A heat gun is not practical as the shaft is inside the wound rotor you woud damage the winding before you got hot enough to destroy the bond.
It is all over I went out last night and it had come loose. the problem was ... rust in the joint. I checked the rotor windings and they are open so the machine is junk as the cost of repair exceeds replacement cost.
