Old 07-08-2004, 04:21 PM
Jake's Avatar
Jake Jake is offline
Holder of only Official Titles
Default "cleaning" your welds.
I was was working on my ring roller last night, and true to form...I pile the wire on when I weld... I ended up taking the flap disc to it to clean it up, and it does a great job. I always like the look of it when I can get it real cleaned up. The question is, am I really messing up the integrity of my welds when I grind them down? most of them aren't structural, I am mainly gluing metal together.
BTW, steel is still expensive, in case anyone was wondering....
Old 07-08-2004, 04:58 PM
Dman033189's Avatar
Dman033189 Dman033189 is offline
Send a message via AIM to Dman033189
Hope you dont mind if I ask another question about cleaning welds. When I go to clean my stick welds I can never get all of the slag. I use the wirebrush but it wont get it all. You can kinda see it in the picture. Also how are my welds doing I am about 6 or 7 months in now. I have trouble ending welds without that dip in the end.
Name:	IMG_0016 (Custom).JPG
Old 07-08-2004, 06:35 PM
boilerman's Avatar
SFT Brewmaster
i use a wire cup wheel on my grinder for removing slag....when you go to end your weld pause a few and let it fill up to get rid of that dip
Old 07-08-2004, 07:18 PM
wolfgangwelding's Avatar
wolfgangwelding wolfgangwelding is offline
I like to use a needle scaller when im in the shop to clean welds. But in the field its not practical because of the need of compresed air. So in the field I like a six inch grinder with a wire wheel. I also pause to fill, under fill at the end of the weld.
no you cant fix it with a hot pass
Old 07-08-2004, 07:21 PM
Main's Avatar
Main Main is offline
Default Glorified highfalutin oceangoing pooper scooper
Jake
Here's an example of some cleaned up welds. The top of this project is made up of six pieces, four for the rectangular piece and two for the drilled and taped tabs.I bevel and tack the rectangle and the tabs leaving about an 1/8" gap. Then weld the three sides with three passes and two or more passes for the tabs. Between the milling machine and the shaper the welds disappear. The tubes and bracket are added later. As far as the welds holding up, no problem and these things take a beating when deployed for their intended use. It's not finished yet but close.
Old 07-08-2004, 07:24 PM
Main's Avatar
Here's a shot of the outside corner finshed off with a 4" grinder with disk and flap wheel. Smoothed off with palm sander.
Name:	outside coner.jpg
Old 07-08-2004, 07:27 PM
Main's Avatar
Inside fillet unfinished. Material is stainless and done with an old westinghouse stick welder.
Name:	inside fillet.jpg
Old 07-08-2004, 07:37 PM
Jake grinding down your welds will not affect the stringth. Just dont v out the weld beed or put any sharp notches or gooves in the welds, this will create a strees point. And if the metal is ever under enough strees to flex or bend that point is where the weld will fail. Smooth and pretty is the way to go.
Old 07-08-2004, 07:51 PM
7018's Avatar
7018 7018 is offline
The dip at the end is called a weld crater<<<<<<<< if i spell that right anyway u can pause or u can just back up over it.It is also the weakest part of the weld!
Old 07-08-2004, 08:15 PM
7018 whats up I agree some times on thinner stuff I have to back up to pause and build up. Backing up on the weld a little will help me from burning threw when I pause to fill the end of the weld.
