  #31
Old 04-24-2005, 02:26 PM
Razorhunter Razorhunter is offline
Here is the anvil fellas. Crossing my fingers that the pics show up...
  #32
Old 04-24-2005, 02:44 PM
tonycamco tonycamco is offline
great find cutter now you have to make a forge i made one piece of cake
will send pic in about couple days and tongs its all over the net on blacksmithing fine hobby!!!!
  #33
Old 04-24-2005, 04:14 PM
Lets try this again fellas. Much thanks to cutter for helping me resize the pics.
So,
Whatcha think fellas? Should I leave this one alone or try to "clean" it up a bit?
I wish the edges were sharp all the way around, but I'm not sure what a resurface job would do to it?
I want to keep the original look. Is there a way of "adding" some to it, to sort of "build it up", and then reshape it and have sharp corners again???
  #34
Old 04-24-2005, 04:15 PM
Another....
  #35
Old 04-24-2005, 04:16 PM
# 3 pic fellas...
  #36
Old 04-24-2005, 04:17 PM
Final pic....
  #37
Old 04-24-2005, 06:24 PM
Franz Franz is offline
Banned
Paul, if you look close at pic#1, you can see where the cap piece is attached to the base of the anvil. Tha cap is what is chipped, because it is hard.
For years now a lot of smiths have been trying different processes to repair or replace caps, including milling them off and replacing with T1 plate for a striking cap.
The problem is the whole anvil has to be red hot as well as the cap, and then, the 2 must be joined to do the job properly.
Another method that has been done with some success is to MIG replace the missing cap metal and then grind or mill to shape. MIG also requires a lot of preheat and postcool, and occasionally results in a broken anvil.
My personal thinking is an anvil can be capped by using T1 plate and brass to bond the cap plate to the base, although I've never tried it.
  #38
Old 04-24-2005, 07:05 PM
Paul,
YOU SUCK!!!!!!!!!!!!
  #39
Old 04-24-2005, 07:26 PM
Thanks ShadeTREE! It feels good to have earned my first "YOU SUCK" on ShopTalk!!
I hope there are many more to come!!
I must say that cutters vise, anvil, Delta Bandsaw, and Clausing drill press have all inspired me greatly to begin a search for old tools that can be brought back to life again!
There is no better feeling in the world than bringing these old quality tools back to life!
It hurts me to see the abuse some people have given them, but I guess that's part of it.
Thanks fellas!
  #40
Old 04-24-2005, 08:05 PM
cutter here are some pic of forge and tools
