Old 01-12-2005, 07:28 PM
Dman033189's Avatar
Dman033189 Dman033189 is offline
Send a message via AIM to Dman033189
Well as of today these are my stainless tig welds. Tommarow I am gonna run a 7018 horizontal pad then if I have time I will try some aluminum tig.
Name:	Stainless (1) (Small).JPG
Old 01-12-2005, 07:29 PM
Dman033189's Avatar
Name:	Stainless (3) (Small).JPG
Old 01-12-2005, 07:30 PM
Dman033189's Avatar
another........................
Name:	Stainless (4) (Small).JPG
Old 01-12-2005, 07:31 PM
Dman033189's Avatar
another......
Name:	Stainless (5) (Small).JPG
Old 01-12-2005, 07:32 PM
Dman033189's Avatar
another........
Name:	Stainless (2) (Small).JPG
Dman033189's Avatar
Last one.....
Name:	Stainless (Small).JPG
Old 01-12-2005, 07:43 PM
X-ray's Avatar
X-ray X-ray is offline
Hey now your pretty good
Can you post up some of the mundane details;
Filler-size/alloy
material-thickness/alloy
shielding gas- cfm/type etc
amperage setting
joint type /position (using welder speak)
Thanks for taking the time to post your work...most enjoyable.
Old 01-12-2005, 07:57 PM
Dman033189's Avatar
Filler-size/alloy
amperage setting
I am using a 1/16" 308 stainless filler rod. The base metal is 1/8" thick. I am using argon at 20 cfm. I usually run 90 amps but I dont use alot of pedal. The welds are flat (1) tee and lap joints.
Old 01-12-2005, 08:28 PM
Dman033189's Avatar
Oh yeah I am using a 3/32 tungsten.
Old 01-12-2005, 08:44 PM
arcdawg arcdawg is offline
don, they are nice welds there......
some hints........
some of them look a little hot.......do you drag the cup ? if not you should try it.....it helps me get a more UNIFORM weld.......
try 15cfm and a gas lens.......
good luck.....
dawg
