Old 02-19-2021, 12:19 AM
JidoukaSS's Avatar
JidoukaSS JidoukaSS is offline
Default Miller XMT 350 MPA with automatic voltage drop compensation
Proper parts, prints, and demo for this project should be done soon. I'm just going to start this thread to give me motivation to get it done.
My dad had a job to do a lot of welding on a CAT articulating hauler so he bought the remote suitcase feeder for the Miller XMT 350 MPA. Initially we only got 12 inches of weld before the suitcase failed caused by a bad internal connection plug. Which will happen when you fill the plugs with silicone grease FFS. After cleaning the pins and putting on some Deoxit, we were back in business. He started welding and it was very inconsistent, so the voltage and wire speed were adjusted with no improvement. After taking a look at it, I figured it might have something to do with voltage drop. The remote unit was connected with a 50 or 75ft cable(100-150ft loop) and the measured voltage drop was around 2-4v. When the voltage setting was increased, the wire speed was also, inevitably causing the same problem.
The XMT is a switch mode welder so I figured it must already have a voltage output compensation loop. Looking at the prints, sure enough the output terminals are tapped with a connection to the front panel circuit board. So, like a linear power supply with sense terminals, which should be connected to the farthest load point, so too should the welder if we want to use settings we're used to. A quick test with a piece of wire connected to the positive sense tap and remote positive buss bar improved the voltage delivery to the unit. If the voltage setting was set to 24v, then the XMT will output what is required to meet 24v as measured from the suitcase buss bar, automatically putting out 26v.
This demonstrated proof of concept, so to make it easier, I added a Local / Remote Sense rotary selection switch to the front panel of the XMT. Local mode would be factory, and remote for suitcase. Ultimately, all you have to do is tie into the Sense feedback connection as can be seen on prints with the Black and White wires connected to #40 Negative/#39 Positive. Connect the rotary switch common to the White(+) wire to Front Panel Connector. Then connect #39 XMT Positive Lug to Local Selector Position and Remote Wire to Remote Selector Position. I also added LED indicators; Local Mode Green, Remote Mode Blue. I've been trying to get
a single piece vinyl sticker made, but I can't figure out why they can't get the scaling right. Picture shown is to test to see it covers up the LED bleed through.
ID:	159572   Click image for larger version
ID:	159573   Click image for larger version
ID:	159574   Click image for larger version
ID:	159575   Click image for larger version
Old 02-19-2021, 12:22 AM
JidoukaSS's Avatar
Remote unit pictures. Voltage tapped at buss bar with 1 amp fuse. I didn't have a proper inline fuse holder at the time so there's just 1/4" QD connectors for fuse.
ID:	159577   Click image for larger version
ID:	159578   Click image for larger version
ID:	159579   Click image for larger version
Old 02-19-2021, 08:56 AM
Interesting. We have several XMT 350’s at work, we use them for the bore welders, as well as with various wire feeders. I can’t say I, or others have encountered rhis sort of issue, though we don’t have the feeders that far away from the power source. Our suitcase feeders are voltage sensing, so I wonder if they would compensate for the drop as well?
Old 02-22-2021, 12:15 AM
JidoukaSS's Avatar
Link to test video, 100ft and 150ft local/remote V-sense results.
https://www.youtube.com/watch?v=dwuSENNMuCU
