Old 02-08-2019, 03:16 PM
Default Trailblazer 302 Diesel
Looking at the above mentioned unit, looks to be just the welder, no cables etc.
It has about 2500 hours on it, I believe it’s a 3 cylinder Kubota diesel.
What to watch out for, what to test/check/try out, and what do folks think it’s worth?
Old 02-08-2019, 03:52 PM
I have that unit, yes, the Kubota engine is an excellent engine.
I paid about 8000 USD new. 2500 hours on that engine is not much but
also it is not new. I would say $3000 - 3500 is a fair price. If it has be
clearly well maintained and not abuse, maybe as high as $4000, treated
poorly deduct as needed. Now I am sure the new price on that unit has
jumped since I bought mine so you might have to adjust up.
IMO, if it is a cream puff with 2500 hours on a Kubota, 1/2 of new might
be as high as I would go. Also Miller will honor warrantees on resold
equipment as long as you have the original receipt; so get it if there is still
warrantee left on it.
I have not had any issues with mine!
Old 02-08-2019, 04:50 PM
If it was 8 grand new, they would want about 8500 beat to crap here. Or maybe 7900 if it didnt run.
Old 02-08-2019, 04:57 PM
Factoring in the dollar difference, I was thinking about 25% more than Shade’s prices here in Canada. Good to know.
I recall seeing different folks here talk about Trailblazer’s being nice units. I’m also a fan of a diesel version, both for longevity, and I feel it’s better than gas for extended down times. I think I should go check this thing out.
Old 02-08-2019, 05:41 PM
And that could be right, for your market, being in the Rust Belt and near
Shit-cago. You can get used equipment pretty cheap. And I a cheap
bastard as well.
The TB is a 2 man machine, you have one guy welding and another
grinding, cutting etc. The aux power on the TB's is a separate set of
windings from the welding generator. So you have true sine wave
230/115V power up to 50 amp surge and 40 amp continuous power.
The welding generator is a 4 pole 3 phase generator so you get a really
smooth arc from it. Also it is a CC and CV power source, as well as
AC or DC. I mostly Stick and MIG weld off mine but I have the basics to
TIG as well less the HF unit.
Do you know what he is asking for it?
Old 02-08-2019, 05:46 PM
Parts listing and cross reference, I use Wix where I can get them.
Old 02-08-2019, 06:56 PM
Asking $4k canadian.
It’s in a cabinet on a service truck, so been largely out of the weather.
Not sure how I would set it up, skid mount it, trailer or what. Will have to deal with that if/when I get one.
Old 02-08-2019, 10:00 PM
Just had a customer come in with a dead 500 amp drive welder on his truck. he will be back Sunday to drop it off as he has to detach it from his service truck first.
I will slide it into my shop start a fire and trouble shoot it in a warm dry place.
Tomorrow I go to pull the deep well pump and replace it I know the motor is running but no load I hope that it vis a blown spline coupler and not no water in the well.
Old 02-08-2019, 11:12 PM
Camaro Zach's Avatar
Customer has a Bobcat 250d (Kubota)welds great but occasionally overheats. Also it is about the most annoying sounding engine I have ever heard. Earplugs are a must when welding within 75 feet of it.
Test drive it and make sure you can deal with the sound.
Buggy
camdigger's Avatar
Roving Reporter
As slow as Alberta's oil patch is, you should be able to get engine drive welders fairly reasonably.
Lots of guys have been out of work for a long time.
