  #1021
Old 03-23-2020, 06:25 PM
OldRedFord's Avatar
Kibble King
This weekend I hope to be able to add trim and flashing and a coat of primer. This will probably be my main entry and I want it to look good.
Tim
  #1022
Old 03-23-2020, 09:14 PM
That's cool
"We live in an era where things that are self-evidently true are denied by maniacs who are then flattered by cowards." Douglas Murrey
  #1023
Old 03-23-2020, 09:18 PM
Looking good. If you can, stock up on your materials, hard to say what may shut down the next few weeks.
Why not steel on that section?
  #1024
Old 03-24-2020, 09:20 PM
OldRedFord's Avatar
Kibble King
Wanted to break up the long side of the building. It's also the street facing side. The plywood is actually plywood siding. 11/32 T1-11. I'm going to trim out the sides and top and maybe the bottom with 1x4 boards and the same around the window.
Tim
  #1025
Old 03-24-2020, 10:28 PM
Do I have a life?
The home supply stores around here have been closing at 6pm! Normally 9-10pm...
HF 80 lunchbox w/tig
  #1026
Old 03-25-2020, 08:26 AM
randydupree's Avatar
Why, Hell Yes!
I had T-111 on a house once,it will need to be painted and caulked asap.
Make sure you caulk the bottom of the boards and paint the bottom too.
  #1027
Old 03-30-2020, 07:00 PM
OldRedFord's Avatar
Kibble King
I added some primer, caulk, and trim. Have drip edge to install across the top.
Not satisfied with my stairs. Took the treads off. I will add 2x4 blocking so my treads will be dead level.
ID:	155330   Click image for larger version
Tim
  #1028
Old 03-30-2020, 08:25 PM
Like the door, it looks good.
You know, an 1/8" isn't going to make a noticeable difference. The stair base you have looks good from here.
The human mind is trained to 7 and 10 stairs, and if you throw one in at 6.5" high and 10 wide, everyone will stumble on that tread.
  #1029
Old 03-30-2020, 10:36 PM
4-13-1949 to 5-21-2023
I have used door shims to level stairs. Works great. Just use construction adhesive and the shims will never move.
LET'S GO BRANDON!!!!
B biggest
I idot
D democrats
E ever
N nominated
  #1030
Old 03-31-2020, 09:18 AM
Dead level is good, a lot of the old time carpenters actually say that a slight downslope towards the toe of the stair is even better. I remember an old family friend talking about that, who was a carpenter his entire life. Can’t ask him though, he’s been gone for years.
Copyright ©2000 - 2025, vBulletin Solutions Inc.
