Tig Cooler build
The cost should come to between $200 and $250 when completed. These pictures are of the frame and layout of the motor / pump, tank (7qt. go kart tank) and radiator (trans cooler) It will fit on my home made cart. As I progress I will post more pictures. I may make a shroud for the fan to radiator and maybe a cover for the unit, let me know what you think about those. Ray |
Looks good so far.
I'd look at putting some sort of filter in. Even in a closes system.
_________________ Jennifer If I defend myself I am attacked. My meaningless thoughts are showing me a meaningless world. My attack thoughts are attacking my invulnerability. I'd like to think of something smart, but I don't want to hurt myself. My google+ page DoALL 36" Another Johnson model J Project Lathe? Maybe..... 1958 SBL 13" Yeti Esseti Aka running welder on 3phase. https://www.shopfloortalk.com/forums...860#post766860 |
I didn't on mine and now will have to modify the case with a shroud to enclose the fan blades, I thought I could get away with out one. Not hard to do on mine but time consuming and annoying to have to redo it as mine is all painted now. Depending on which way the blades are positioned, I think it is better to suck the air in though the ribs and not push air out through the ribs. If that makes sense. I built it several months ago but still haven't posted it up yet. I will post up my build soon as I get a chance to scratch myself,as I have been busy lately. One thing to be aware is that if it is a Proconn pump, they do come in a variety of pump pressures and volumes per minute and the side pressure relief valve is not designed to be a permanent pressure relief valve. Most TIG/MIG torches don't go past 50-60PSI and allow up to 4lt per minute before the linings blow so make sure that you don't go past that. Ed.
Making metal scream because I can ----------------------------------------- Miller Auto Invision 456 + S-62/4 Wirefeeder 180A MMA welder Spot welder 16 speed pedestal drill 16Ft3 air compressor Hafco BS-912 Bandsaw Everlast Powerpro 256 Recipient of the Finger Award™... twice |
haha this is awesome, i just redid my home built tig cooler set up and i was logging in to post then i saw this. i could see spending more then 200$ so i built mine too!
Btw how u liking that everlast machine? I wanna know what involved w getting the right dinse connections for the everlast units. Good job also on your project
I just upgraded to a wp-20 torch (but cannot use it until I finish the cooler) and needed a dinse connector My LWS where I ordered the torch also supplier the Dinse for $28. that was way less then anyone on line. The torch and liner was $138 for a WP-20 flex head with 25 ft cables. Could not touch that on line. The LWS is family owned and I have purchased my gas and consumables there for a couple of years, great guys. Ray |
That's awesome. I bought a power plasma 50 from everlast and for 700$ its sooooo with the money. I was thinking about selling my Lincoln 175 for a everlast 200 but I was scared about my wp20 connections. I'm glad you like yours and practice makes perfect! Keep the pics commin!
Hey RAM. Where'd ya get Ur trans cooler? I like how compact your setup is. Thanks!
The trans cooler came from Summit racing and is about 7 x 12 inches or so (cant remember the exact measurements). The base for the cooler is about 9.5 x 21.5 nad build to fit on my home made cart next to the plasma. I got the remainder of the fittings, clamps and hose yesterday but this weekend is already busy so I hope to finish it early next week I wil post more pictures then. Ray |
Here are a couple more pictures of the motor wired and iin its final location, and the trans cooler and fan shroud fabricated and installed.
I hope to start plumbing it on Monday I ordered the fittings but two are incorrect but I hope to come up with a workaround with parts found locally if I can. |
Tags |
cooler, tig, torch cooler |
