Old 12-01-2015, 06:11 AM
Cavalry's Avatar
Cavalry Cavalry is offline
Below Wholesale
Default New Plasma
Early Christmas present to myself Powermax 65...now I have a reason to finish up my CNC table!
I knew it before I opened the box but I am a little annoyed it only comes with a 3Ø cord with no plug and no single phase whip. Another $100 for that....Would it have killed them to put a twist lock on the end and give you a cool 6-50 adapter like others do?
Old 12-01-2015, 04:10 PM
Bender's Avatar
Bender Bender is offline
One Lone Sub
Sexy!
My Hypertherm 600 has been flawless.
Unless you count the time I dropped a 10 pound piece of angle iron on the torch
Boise Paint Contractor
Facebook
How fortunate we are!
Old 12-01-2015, 06:26 PM
I would have thought there would have been a waiting period......
Old 12-02-2015, 10:36 AM
jimcolt jimcolt is offline
The Powermax65 will operate on any voltage between 200 and 600 volts, single or three phase power. Because of all of the available voltages......there could be as many as 30 different plugs required in order to meet electrical codes worldwide. For this reason, there is a power cord supplied that you can install the correct plug for your shop. If you are using it on single phase, simply clip off the red lead and use the Black and white as hot leads and the green as the safety ground......no need to replace the cord with another. The instructions for doing this are in the operators manual......or you can call tech service or contact me at any time with questions. Thanks for buying the Powermax65 from all the employee owners at Hypertherm!
Jim Colt jim.colt@hypertherm.com
Old 12-02-2015, 11:07 AM
Cavalry's Avatar
Below Wholesale
Hey Jim, I forgot you were on here.
Dont take my comments as too harshly, I understand why you configured it in that manner. Even though I have 3Ø available I chose to go single because no matter where I go there is a likelihood that I can plug it in and go. I feel as though a lot of guys running this size of machines are doing the same thing.
I fired it up for the first time today and very happy with the test cuts I made.
I don't suppose you would want to send me a cover in exchange for a in depth review here?
