Old 12-22-2019, 10:10 AM
tnmike's Avatar
tnmike tnmike is offline
Sultan of Scrounge
Default Subaru Forester oil consumption
I've been a Subaru fan for years. That being said my wife has a 2012 Forester that drinks oil. It was checked by a dealer under the lawsuit settlement and they said it was fine. Pure BS. The preferred oil is 0-20.
What do you guys think about going to 5w-30? I'm not sure if it will slow the consumption but it's worth a try. I'm sick of adding a 1/2 quart of oil every two weeks.
Klaatu barada nikto
Old 12-22-2019, 10:58 AM
astronut's Avatar
astronut astronut is offline
One thing to consider if the vehicle is still under warranty is if the switch will affect warranty coverage of the vehicle. Just a thought. This would be a good question for STW.
Lincoln Weld Pak 100
Giant Tech Arc 200
Miller Roughneck2E
Old 12-22-2019, 10:59 AM
Shopmonkey's Avatar
After that first 1/2 quart is gone, will it continue to use oil?
RIP Cutter
Old 12-22-2019, 11:02 AM
Norm W's Avatar
Norm W Norm W is offline
It seems that all the car companies are going for that last .001 of corporate mileage. They run the rings so loose that the oil just goes right by them. Honda does the same thing. I don't think that the 5-30 would hurt the engine, it might lower the mileage a bit (.001?), but what costs more? A fellow that has a Honda with the same problem, said the car stopped using excess oil at about 60,000 miles. Is that a bit long for the rings to seat?
Old 12-22-2019, 11:04 AM
Time for the Bon Ami treatment
Old 12-22-2019, 11:43 AM
Is it leaking oil or burning oil? How many miles on the car?
Yes, they are squeezing every 0.001 mile of efficiency out of them.
In reality the tolerances are tighter to run the lower viscosity oils.
Wait until you see the 0W-16 and 0W-12 oils that are on their way.
Going with a higher viscosity oil will 1) not solve the problem but. 2) could
starve the engine critical components do to low oil flow due to the higher
viscosity in a the tighter tolerances in the engine.
Oh and don't think just because you have good oil pressure that everything
is getting lubricated when you switch to the higher viscosity oil. The oil
pressure sensor are generally just after the filter and only represent the
pressure in the main oil galleries and not a confirmation of good oil flow
in the bearings.
Old 12-22-2019, 11:46 AM
I have a Ford Exploder, with 217k on it, does not burn any oil, does have
a few minor leaks that do not require added oil over my 6k oil change and
it runs 5W-20.
It is not the oil viscosity...
Old 12-22-2019, 11:50 AM
How often have you changed the oil in the engine?
What oil have you been using? (please for the love of god don't tell me you use
the "high mileage" oils in it.)
Do you change the air filter when you change the oil?
What kind of driving is done, short trips, long trips? Does the engine have time
to come up to temperature?
Are you the original owner?
Old 12-22-2019, 05:03 PM
I'm still driving my 84 Subaru, was looking at 2000-2006 Forester because the hp and mileage ratio is better than most cars but it appears they have an inherent head gasket issue that Subaru could not figure out, likely need to re-torque the head gaskets at 60K miles as I did on my Subaru and mine did need it.
On the other hand I just about had it with replacing CV boots, may only look at rear wheel drive trucks.
We don't have the same motors but they are both "flat" and Subaru's.
External leaks on mine.
the oil pump seals need to be replaced every 60K miles
other seals, mainly the front and rear crank shaft seals 80K miles
needs a pan gasket.
As for internal Oil sucking
My motor
PCV system had a blocked vent hose, the hose/vent reduces PCV vacuum about 50%
the blocked hose increased PCV vacuum that was sucking oil and spitting it through the PCV valve just under the carburetor.
Oil turned to a "hard" plastic tar, see picture.
Has to do with flat motors,
It was noted in my manual that this vent hose was to prevent oil from being sucked in when (IIRC) the car is making banked right turns.
My PCV valve is mounted in a horizontal position so an after market PCV will not work although auto parts stores state they will... they will not... after-market when installed made a continuous sound like a gang of angry bumble bees.
IIRC my PCV does not use a spring as after-market do have springs.
If the oil is being burned into the exhaust the CAT will go bad sooner than later.
Name:	Carb P5230037.jpg
Old 12-22-2019, 07:04 PM
Shopmonkey's Avatar
My wife's '02 Highlander ate a quart of oil quite regularly. We had it in for a valve replacement as well as valve guides and, now, the oil stays where it belongs.. in the crankcase.
RIP Cutter
