Old 01-24-2024, 07:09 AM
VW cat VW cat is offline
Default Water heater anode question
I'm replacing my leaking 4 year old 40 gallon water heater with a similar GSW unit. I removed the aluminum anode from the old one, so I could heat it with lines from an outdoor furnace heat exchanger. The dealer back then said that's the only way it can be done.
I got the idea, why not cut the threaded end off the anode and just drop it in the tank. Will it work, or is it better to suspend ,allowing water flow past?
Old 01-24-2024, 02:24 PM
Has to do with electron flow direction and needs to be attached to the tank for it to work.
Most water heater Tanks are guaranteed for 5 to 10 years, you should call the factory with a serial number for a replacement.
Old 01-24-2024, 08:21 PM
I’ve seen hot water heaters with side arm heaters from wood boilers. Pull bottom drain valve out and top relief valve. Replace with tees, to keep drain valves and relief valve in place. Connect the two tees together, with a heat exchanger made from a larger piece of copper pipe with a smaller one inside that connects the top and bottom tees into the water heater.
I tried to draw a picture, and included a couple pictures of a set up in a house that I just switched out the wood boilers last December.
Old 01-25-2024, 07:16 PM
I never thought about plumbing it that way. My heat exchanger is 5' long. I'm guessing it would heat water just as efficiently from the relief valve port, as off a top port, where the anode is...
Old 01-25-2024, 07:24 PM
IIRC, the cold water inlet/input has a long tube that forces the cold water to the bottom of the tank closer to the burner.
If you look in the cold/hot threaded holes you should see the tube.
Old 01-25-2024, 07:49 PM
I'm using the model with the cold intake at the bottom. I'm not sure why, I guess because the first one 45 years ago was like that. I'm always afraid the grand kids will run into it with their pedal cars.
Old 01-26-2024, 01:14 AM
Just noting my information is more on gas water heaters don't know much about electric ones.
about 2 years ago I was in Lowe's pricing Gas water heaters there were some priced about $200 cheaper but were tagged "not for home use or something to that wording".
I asked and that person stated the inlet is at the bottom and for homes the inlets were at the top.
IIRC,
the bottom inlets are for maybe mobile homes or RV's where the water supply lines come in.
Slab homes run the pipes in the attic so they connect from the top.
