![]() Anyway, drove over to the valley to a huge farm, and in the maintenance shop was the cutter and parts.. Took it home, and messed with it a bit, and it was dead like they said, although it did turn on, just no spark.. I was trying to retro some parts out of the torches, and took the torch off the machine. Had the adapter that fit the old machine opened up,and a couple of the wires/ pins was loose, I reinstalled the torch,and it fired off.Just a few more adjustments it was cutting like new. Really better than new, because of the better torch setup..These machines are only 35 amps output rated , but it was outputting 38 amps and a good strong arc.. That means 40 amp consumables can now be used with the shielded tips or dragged with good consumable life.. The only downside is the machine is heavy, at 68 pounds, but it is built like a tank. Just sitting on my other dinosaur, the Esab CV-353.. ![]() ![]()
HARLEY-DAVIDSON: "THE MOST EFFECTIVE WAY TO CONVERT GASOLINE INTO NOISE WITHOUT THE SIDE-EFFECTS OF HORSEPOWER":evil: |
For $150
Ok then, YOU SUCK!
Nice find.
Really, I had to go for a nice day trip of 450 mile round trip. I wanted to check that area out for a possible future living area. It did cost me about $40 in gas,and not too bad at $4.50 a gal..
![]() The "50" must have meant something else ? |
Nice clean cut!!
Pakmaster 38 = 3.75"
We have an old Hypertherm Max42 plasma cutter that we bought sometime in the 80s. I was never really that impressed by it but it worked OK and we did use it for a lot of stuff. It was hard on consumables; we seemed to go through them pretty quickly. As the torch deteriorated it got to the point where it cut so bad that we hardly ever used it.
About 20 years ago Hypertherm came out with a completely new torch setup and, in addition to using them on all their new machines they made torch assemblies to fit all the old power units. We bought one for our machine and what a difference it made! The old girl has been working great ever since; it's really been like having a new machine, it works that much better...
So my old xfomer unit, a "Pak-5" is a 55amp machine.....Must have changed things in the labelling department
