  #121
Old 04-04-2012, 08:16 AM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Jack, As far as my local codes go, they do not care if you use steel or copper. NY is a funny duck, they allow copper tubing to hook up the controls on heating system but not for air lines.
I have done air lines in several places in copper without any code trouble, we did have to explain to an inspector that copper was allowed by the Feds for airlines, he did some checking and then ok'ed the installation. He said he had not run across it before.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
  #122
Old 09-17-2018, 09:09 PM
Lu47Dan's Avatar
Dan.
Bump, bump....
Sent from my Samsung J7 using ShopFloorTalk mobile app
Hobart 175 Mig
Craftsman O/A set
  #123
Old 09-17-2018, 10:31 PM
JP_in_STL JP_in_STL is offline
Dan - Thanks for bumping. I read all this tonight just now. Lots of good info. Only possible mistake I see is I ran TypeM, the red stuff. Its rated higher psi than I will ever need and my lines are mostly protected. I'm in a home workshop so I think I'm fine with the thinner pipe. Thanks for the info - JP
Stanton, MO in a holler' and the ground is hollow
Hobart Handler 210 - HYpertherm 45XP - and a big hammer
  #124
Old 09-18-2018, 04:10 AM
Lu47Dan's Avatar
M should be fine..
I really need to finsh this thread.
The copper / steel / PVC debate will continue.
Dan
Hobart 175 Mig
Craftsman O/A set
