![]() Picked this set up online for $89 from Home Depot. Ratchet alone was $79 so for another $10 with free shipping I got a "trickle" charger and lightweight "baby" battery along with it. I've had a need for a battery-op ratchet and this fit the bill. HF had a Bauer (or whatever) with skinny battery for $100ish and Milky and Dewey have their own sans battery for $150ish? Price was a bit of a factor as I am already vested in Ryobi "ONE+" 18v batteries. (about a dozen...) Seems to work OK but I don't have anything to test the torque yet. Trigger is variable which is nice. Lawyer switch that locks the paddle can be turned to "unlocked"--a necessity. Head can be rotated in four 90^ positions. Came with a 3" extension which stores near the battery in a well-designed hole complete with friction rollers to keep the extension in place. Has a spot for a hook near the battery not that I'll be hanging it from my belt... ![]() Speaking of batteries, I've been buying a 2-pack of 4Ah every BF for the past several years. The last two years I bought the 2-pack of black batteries for $80/2 but just now noticed they are called "Lithium" vs "Lithium+"... ![]() ![]() ![]() ![]()
TA Arcmaster 185 w/tig/stick kit MillerMatic 252 w/3rd gen 30A MM140 w/o AS, w/CO2 Hobart (Miller) 625 plasma Hobart 250ci plasma Victor O/A (always ready, but bored) TA 95 lunchbox w/tig 45ACP Black Talons for those stubborn jobs... |
I had a small need for the ratchet so I tested it on a couple nuts I needed to tighten. Couldn't really torque them down because the application did not call for it.
Right off the bat I noticed a somewhat major shortcoming and that is that the battery offsets toward the paddle. So tightening a bolt on a flat surface would require the included extension to approach it at 90^. ![]() ![]() I put it next to my good ol' Chicago Pneumatic 3/8" that I used to use every day back in the wrench-turning days. Note the exhaust towards the head and easy-spin direction knob. The paddle allowed feathering of rotation but many a time it also got wedged on in a tight location jamming my knuckles into the radiator or other sharpness! ![]() ![]() ![]() CP is next to some extensions I will probably return ($10). They are not anything I can't replicate with adapter and extension already... PS: that is a leash that pops in the battery hole to hang the ratchet with... Also shown is another CP, but this is a HF "Central Pneumatics" 1/4". The "on-off" air switch is dead and it was a cheapy that lasted a month or so. ![]() ![]() Note the difference between the sizes of heads. The Ryobi head has been turned 90^. Ryobi also makes a 1/4" drive version of the ratchet although I'm not sure if it comes with an extension. The head size appears the same. I have 90 days to return it so that will give me time to thrash it to see if it will last 30 years like the CP has... ![]()
TA Arcmaster 185 w/tig/stick kit MillerMatic 252 w/3rd gen 30A MM140 w/o AS, w/CO2 Hobart (Miller) 625 plasma Hobart 250ci plasma Victor O/A (always ready, but bored) TA 95 lunchbox w/tig 45ACP Black Talons for those stubborn jobs... Last edited by mccutter; 12-02-2020 at 03:25 PM. |
Can't you just rotate the head?
Drawing by Smartdraw |
Yes, but it puts the paddle in an unorthodox location. I'm used to the paddle being on the side where the socket is... I'm nit-picking here but have other tools such as a right-angle drill where the battery pivots instead of the head.
They do have this Husky "Special Buy" for $60. LINK My attraction with the Ryobi is I already have a bunch of batteries for it with at least a few being somewhat fully charged all the time. Pop a battery in and go to work...
Just as an FYI, I ordered the two pack of 4 ah, Lithium One +, batteries this morning for local pick-up, $79. I picked them up about two hours later and they were as advertised: https://www.homedepot.com/p/RYOBI-18...P145/306703572
Hers are the links to the ones u picked up they are 12v but last several days use unless really hard use...
https://www.oreillyauto.com/detail/b...tt0002/5687998 https://www.oreillyauto.com/detail/b...e+impact&pos=2 Both are decent and compact and have plenty of power and my son bought this one and I was surprised it brakes heavy bolts loose on transmission bell housing bolts and motor mounts even rod cap bolts on 454 chevy engine we tor down. https://www.oreillyauto.com/detail/b...e+impact&pos=0 |
In other Black Friday purchasing, I got this breaker bar set for $20. I haven't decided if I will be returning them yet... ![]() ![]() ![]() ![]() PS: keep in mind I ordered a number of items and was perfectly fine with them all shipping at the same time... Expect corporate waste like this to continue as long as there are lock-downs and yet there are continued calls for higher minimum wage. ![]() ![]() ![]()
My local store did not have these and they are not available online. They will tell you store availability online if you enter your zipcode or similar. I happened to be passing by a store in my travels today that I knew had them. I thought they were all worth the $10 each they are getting for them.
![]() The pick tools and scrapers are decent and the handles are comfortable. The packaging was a little tough to get into... ![]() The tie downs I chose instead of a $6 or $7 4-pack they had in orange. I have plenty of those. PLUS they came with a carry bag which is what sold me! ![]() ![]() ![]() The headlamps are Christmas gifts early to the younguns'. Still waiting on a couple Husky wrench racks for $15. In related tool investments today, I picked up the Lisle trim tool to complement my 30+ yo Snappy. Made in US (still)... ![]()
