Old 01-02-2021, 07:37 PM
That's what they were built for. Long life and fuel economy. First time I saw one was in 1972 when I was moving to the Yukon. All along the Alaska highway were these gas stations/roadhouses that were family run businesses. They all had these Witte engines powering a generator. I talked to one owner and he said those engines had been there and running since the construction of the road. And they would still be running, but once the road was paved people stopped less and cars went further when not fighting mud, so they died out.
I always promised myself I would have one, so when this came along I could not scrap it..
Thanks Gerry sorta now I have to find one of these or a listeroid for the coming lean times. The Witte would be way better for me because it is a natural for running off a woodgas generator setup.
Old 01-02-2021, 09:51 PM
Norm W's Avatar
Norm W Norm W is offline
With propane and a hot mag impulse, you really shouldn't have to pull the flywheel through fast at all. Just pulling it over TDC should do it. If your regulator has a priming button it may help.
Old 01-02-2021, 11:45 PM
I know
I have a lister type, and it is everything they say for ease of starting and economy, bit the Witte takes all that and quality to a high level.
Old 01-02-2021, 11:54 PM
It takes little to start it if you can get it rolling over. And the amount of cranking we did was impressive. I never would have been able to troubleshoot it without the electric start.
Now that it is all ironed out and carb adjusted and fed right, it will start as you say it should.
Old 01-05-2021, 07:23 PM
Yesterday I filled up the coolant, and started it up and let it run. After it got hot, I started to feel some push back from the governor, not great but something. I took off for a couple hours to help someone and then when I came back it seemed to hold the rpm much better.
Started it up this morning and tach'ed it at 630 rpm and if I flicked the throttle up and let it go it returned to it's speed setting.
So I think the stuck weights are freeing up after the long sleep. I found out that Arrow sold the parts and rights to Sooner Machine, so I called them and they said they could scan and send me the exploded views they had and part numbers. And they did.
Old 01-05-2021, 07:29 PM
This is quite the scavenger hunt finding info on this project. But, it sounds like you are gaining on it
Old 01-05-2021, 09:51 PM
I got nothing from The oil field shops in Casper.
Old 01-07-2021, 10:54 AM
Nice score,
I am jealous of it. Very little likelihood of finding them here in oiless aridzona
Old 01-07-2021, 10:19 PM
There are a few sources in the US. There is also Chad Equipment sells for about $1200.
I took the lid off the crankcase today as I noted a gasket seep, and I am guessing the crank rod journal is 2.75" and a monster con rod. It all looks new inide.
20hp rating Bwaahaaha
Old 01-08-2021, 01:01 PM
moe1942's Avatar
moe1942 moe1942 is offline
Voice of Experience
Well Mama will be happy..it will keep you out of the bars..
