Rest In Peace Cutter
Old 04-13-2015, 08:11 PM
Default Another what the...
So, by buddy Steve calls me the other day and says he can't move the van.. He started it moved it forwards, put it in park and shut it off.. Now it won't start and it doesn't feel like the shifter isn't doing anything..
I said sounds like a stuck shifter linkage ( the van sits months at a time).
So I pile my miserable self into the car and drive over there.. 8 minutes with traffic.. And I pull (Did I mention Steve is a hard worker but has almost no mechanical /automotive in depth knowledge) the engine shroud off and look inside to find the part that holds the cable is completely hanging loose..
Turns out they used carbon steel bolts in an alumium that must have high magnesium in it.. The corrosion expanded around the bolts and completely exploded the housing bolt bosses for the shifter cable bracket..
So I told Steve there is no guarantee this won't fry the transmission since I'll be welding almost directly on the gear case itself.. He said go for it..
First thing first I take the grinder and clean off all the schmugg that has formed (schmugg is corrosion to the extreme).. I then go to Lucky and drill and tap what I am guessing is the right length spacers out of alum to act as the replacements once welded in..
I then try to feed the alum mig wire thru to the 20ft push pull gun and it keeps gettting jammed in the lining.. I take the lining out and no pinches or anything.. I"m like what the.. Then I notice there is some fines at the end of the liner.. I take the blow gun once the liner is out and blow it out..
I then reinstall it and the same thing but this time I persevere and it pushes out a bunch of crap.. I didn't swap liners last time I ran steel wire.. It must have has some rust on it.. Fer..
So it was a super tight area in less than ideal conditions and I welded the crap out of it.. It's not pretty but it will work..
Between the shifter fix and replacing the rear axle brake line it was 5 hrs out of my life.. But it was helping a friend and I still owed him 100.00 in labor for the plow I put on the 2001 F350..
ID:	123553   Click image for larger version
ID:	123554   Click image for larger version
ID:	123555   Click image for larger version
ID:	123556   Click image for larger version
_________________
Jennifer
My google+ page
DoALL 36"
Old 04-13-2015, 08:44 PM
5500bill 5500bill is offline
good job on the repair, around here they would not even think of welding it.
Old 04-13-2015, 09:19 PM
Another job well done you are a problem solver!!!
Old 04-13-2015, 09:54 PM
A barter deal. My favorite kind.
Woodrow Wilson
Old 04-13-2015, 11:24 PM
King of Obsolete's Avatar
Published Author
another fine repair. keep up the good work, i know i would have had problems with too much gravity on my welds, lol.
thansk
KoO
Published Author
King of Obsolete
Cat Train Tours
Old 04-14-2015, 12:38 AM
Gadgeteer's Avatar
Yup, finesse at its finest.
Old 04-14-2015, 05:57 AM
Around here it would have been the same deal.. Just a good bubble gum fix.. I even whacked it with a hammer a few times..
Hopefully.. it will last..
I love barter too..
thansk
KoO
Published Author
You weren't alone in that department.. JBweld might have done the job..
Your to kind.. It left the shop looking like that and I'll denigh it if anybody asks...... WEll thats only if it breaks at the weld..
_________________
Jennifer
My google+ page
DoALL 36"
Old 04-14-2015, 08:18 AM
Scrapper Greg's Avatar
Nice job, Jenn. Yes barter good!! And I like your use of proper technical terminology!!!
MAGA
Old 04-14-2015, 09:12 PM
Gadgeteer's Avatar
Smile
Your to kind.. It left the shop looking like that and I'll denigh it if anybody asks...... Well thats only if it breaks at the weld..
Ah, but function is job one. I don't care if it doesn't look pretty, as long as it works.
Old 04-14-2015, 10:16 PM
kiwi's Avatar
kiwi kiwi is offline
Nice work, I'm sure he appreciates the help.
Nick
