Rest In Peace Cutter
Old 08-08-2010, 09:08 AM
endmill endmill is offline
Default Show me your metal saw horses
looking to build some metal saw horses,got some 6" channel for the top looking for some leg idea's. I thought it would be neat if the legs could be pivoted and bolt so they could be stored.????????????????????? Thanks Dave
Old 08-08-2010, 10:43 AM
DDA52's Avatar
DDA52 DDA52 is offline
Blood, Sweat & Concrete
These aren't quite what you are after, but the legs do pivot. Maybe they will inspire an idea.
Here's the link to how it was done.http://www.shopfloortalk.com/forums/...ght=horse+herd
Edit....FWIW, I have had well over a ton on the four footers I have. They are holding up extremely well.
Don
Old 08-08-2010, 01:11 PM
Unless your doing some Heavy work I think 6" channel is a bit over kill. The older you get the lighter the horses you want.1 1/2 X 3 inch tube or something on that order works for most jobs. Build your super horses and leave them outside for special occasions. IMO
Old 08-08-2010, 01:41 PM
Vernon's Avatar
Vernon Vernon is offline
Default Saw Horse
Well here are my sawhorses. Top rail is 1"x 3" Rectangler tubing Legs are 1" x 2" Rectangler tubing. 1/8" wall on all the tubings well thats it. I would put 1500lbs on each one and never look back
Vernon
ID:	64202   Click image for larger version
ID:	64203   Click image for larger version
ID:	64204   Click image for larger version
ID:	64205   Click image for larger version
Due to the lack of effort today Tomorrow has been canceled...................
Old 08-08-2010, 04:22 PM
slopdog's Avatar
slopdog slopdog is offline
storage was an issue for me so when i built a set of sawhorse,s i built 4 ends (2 for each ) like an A with a short peice of squarewelded to the to topof the A.. tubin then the the top was a peice of sq tubin that would fit into the ends ,I i would stand up 2 ends then slip the center peice into each end peice a nut was welded on the botton of each end peice and a bolt to tighten it from moving it was easy to take apart and very little room needed for storage ,
After all is said and done ,, more is said than done .
Old 08-08-2010, 10:38 PM
Her's mine. Made out of sked 80 pipe and drill tubing. They will sink into the ground or the floor with alot of weight on them.
ID:	64248   Click image for larger version
ID:	64249   Click image for larger version
Old 08-09-2010, 03:14 AM
JohnBoy's Avatar
JohnBoy JohnBoy is offline
Director of Languages
Vernon, did you actually stack them like that to tack them up?
They slot into each other absolutely perfect.
Old 08-09-2010, 09:34 AM
Vernon's Avatar
Default Saw Horse
No I made a jig so all the legs came down in same spot each time.
It was layed out on a machine surface so they where 100% level.
And all the leg pcs where cut and made the same.When I worked for dad we made some Alum one that where the same size.
Also made great big set 4" x 6" with 3/8" Wall "Very Heavy"
Vernon
Old 08-09-2010, 05:14 PM
Default Thanks guys
great idea's!
Old 08-12-2010, 11:57 AM
I have a pair of these: LINK
