Old 09-13-2018, 09:24 PM
Nomoreusmc Nomoreusmc is offline
Default On the subject of consumables
So what consumables do you keep on your rig? I would like to keep the learning curve as shallow as possible. I really don't want to look like a jackass in front of a customer.
Right now I have
10lbs Lincoln excaliber 7018 3/32
5 lbs fourney 7018 1/8
10lbs fourney 7018 3/32
10lbs no name 6011 1/8
3/32 and 1/8 4043 aluminum tig rod
1/16 ,3/32, and 1/8 70s-6 steel rod
1/16 and 3/32 Stainless
Silver solder
What else should a guy have?
Sent from my [device_name] using ShopFloorTalk mobile app
Hobart Titian 8000
210mp
Square wave 200
Everlast 160stl
Powerkraft 300
2 Loose Screws Fabrication
Owner
Old 09-13-2018, 09:28 PM
All depends what work you’re doing.
What sort of market are you looking at? If it’s general repair work, versus pipeline, versus fabrication, all makes a difference.
Old 09-14-2018, 07:55 AM
My truck is loaded with what I need on the day of the job. For me an aluminum or SS field repair is rare. Most times I either go out with 7018 or a mig feeder.
Old 09-14-2018, 07:09 PM
Well the truth is I don't have a clue. I am about to move in the dry part of Colorado. If the welding is as different as the farms..... Let's just say I have a lot to learn. I would say general repair work, but I have thought about specializing in something but I don't know what. I was an electrician in the Marines, spent time building radio and TV stations, ran a speed shop/powder coating shop, and I have done handyman work. With the odd welding jobs I have I really think I have a good skill set. Just need. To learn where and how to apply it for financial gain.
Hobart Titian 8000
210mp
Square wave 200
Everlast 160stl
Powerkraft 300
Owner
Old 09-14-2018, 07:11 PM
What size 7018s do you use? I was leaning towards stocking mostly 1/8.
Hobart Titian 8000
210mp
Square wave 200
Everlast 160stl
Powerkraft 300
Owner
Old 09-14-2018, 08:30 PM
When I used to work on our crusher spread doing repair and maintenance 90 percent of the welding was done with 1/8" 7018. I think that would be true in any maintenance work.
Old 09-15-2018, 08:13 AM
camdigger's Avatar
Roving Reporter
From what I've seen, 1/8" 7018 and 1/8" 6010/6011 will do 80% of any General fab or maintenance welding. Some prefer to stock 3/32" 7018 too so they can run the two different rods at the same settings.
Other rod types are job specific, like hard surface or high tensile rods....
Old 09-15-2018, 08:51 AM
When I was running my business, almost all of my mobile work was steel,
so SMAW, I ran a lot of 6010 and 6011 rod as it was all dirty, rusty, etc.
Also later on I ran flux core wire out of a suitcase feeder off my Trailblazer.
If I was GTAW welding on the road it was always inside a building. But
those were few and far between.
Silver solder is not a bad idea to have on board.
Like mentioned above, a lot is going to depend on what your local market demands. But you have a good start.
You did not mention oxy-fuel, I would look at propylene for your fuel gas if you are going to be mostly mobile.
Old 09-15-2018, 09:34 PM
I have a 50 amp plaz and a 25 gallon LP tank for conversation to oxy propane and my baby torch
Hobart Titian 8000
210mp
Square wave 200
Everlast 160stl
Powerkraft 300
Owner
Old 09-15-2018, 09:40 PM
I just like 1/8 better. Runs a good size bead, puts down good amount of metal and just "feels" better. 3/32 just feels like you have to multipass everythingClick image for larger version
Hobart Titian 8000
210mp
Square wave 200
Everlast 160stl
Powerkraft 300
Owner
