Old 10-09-2008, 04:44 PM
Dallas B's Avatar
Dallas B Dallas B is offline
Duke of Rock
Send a message via Yahoo to Dallas B
Default Help with a 3 phase deep fryer
How can I make my 3 phase deep fryer into a 240 v for the house. I have only 240v in the house.
Name:	100_2037 [800x600].JPG
ID:	36727   Click image for larger version
Name:	100_2041 [800x600].JPG
ID:	36728   Click image for larger version
Name:	100_2038 [800x600].JPG
ID:	36729   Click image for larger version
Name:	100_2043 [800x600].JPG
ID:	36730   Click image for larger version
Name:	100_2042 [800x600].JPG
Dogs are nicer than people. Not only that, but dogs are smarter than horses. *Winner SFT Best Sig Line 2005* ( http://www.indierevoltmg.com/ )
Old 10-09-2008, 05:07 PM
Fla Jim's Avatar
Fla Jim Fla Jim is offline
Harbor Freight Backslider
Do you have a schematic for it? It probably has three "Y" connected heating elements. You might be able to drop one of the legs, and use it at a reduced heat with single phase. But you need to see how it's wired, control voltage, temp controls etc.
Jim the Shop Rat
From Jim’s Magic Garage®
Old 10-13-2008, 06:43 PM
May Pop May Pop is offline
If it has a drawing on the cover show it to us. The three heating coils may also be hooked up in a delta [triangle] also. Take the cover off and shoot some picks.
Old 10-13-2008, 07:48 PM
Dallas B's Avatar
Duke of Rock
ok...thanks
Old 10-14-2008, 10:48 PM
RancherBill's Avatar
there has to be an answer
What's the model number? It is hard to see in the picture.
Old 11-16-2008, 11:34 PM
Soapy's Avatar
Soapy Soapy is offline
Default Fryer conversion
Most likely your single phase current in your residence, is 240volt, and your plate on your fryer shows 208volt. Without changing the elements to 240volt rated units, your element life will be shortened considerably. Most all commercial heating appliances arrive wired for three phase current, and it is the installers responsibility to convert it to single phase. The cover plate should have the info you need on the inside of it.
Ed. ( Retired commercial appliance tech.)
Old 11-17-2008, 01:14 PM
Dallas B's Avatar
Duke of Rock
So are you saying that I can buy a 240 v ac elements?
Old 11-27-2008, 11:20 PM
Soapy's Avatar
Default Fryer
Vulcan Hart was bought out several years back by Hobart Corp. You need to contact your nearest Hobart service/parts shop, to determine if the elements are available. Sorry about the delay in posting an answer.
Old 11-28-2008, 12:11 PM
camdigger's Avatar
Roving Reporter
I don't under stand why the need for new elements?
Correct me if I'm wrong, but...
3 phase 208v is within 10% of 220v which should be close enough for a coil.
3 Phase power is simply 3 different single power lines run in a specific phasing or relationship.
There should be 3 different heating coil elements, each assigned to a single leg or line of the 3 phase input. Conversion to single phase should involve separating the inputs to the individual coils and setting the heating elements up to run in parallel (ie common inputs and outputs to each).
The control should be a simple on/off thermostat controlled affair that calls for power when the temp is lower than set point and shuts off when hot enough...
What am I missing??!?
Cam
Old 11-28-2008, 04:08 PM
Broccoli1's Avatar
Broccoli1 Broccoli1 is offline
There is a Hobart Service sticker on the Fryer.(Photo 1)
Ed Conley
MM211 AS
MM252
Spoolmate 100
SO 2020 Bender
Miller 125c Plasma
TA 185
