Old 04-08-2012, 11:14 AM
David R David R is offline
Talking Crappy welds
This came into my shop, its a pump stand of some kind.
ID:	89609   Click image for larger version
ID:	89610   Click image for larger version
ID:	89611   Click image for larger version
ID:	89612   Click image for larger version
V350 pro with advanced panel Bunch of other Lincoln machines Hypertherm 600 Arcmaster 185 Estwing BFH
Enough knowledge to get into trouble
Old 04-08-2012, 11:20 AM
Talking
Fitup was good for the fine welding job. I ground off all the crap and installed my own welds. I wire brushed the inside spot and welded that first.
Mig, .035 wire at 250 inches per minute, CP (controlled power) 1.5 on the machine. Controlled Power means 1.5 KW of power regardless of the volts and amps. Its odd, but works quite well once I got the hang of it. gas was 92 argon 8 Co2.
I charged the customer 1/2 hour.
ID:	89614   Click image for larger version
Old 04-08-2012, 11:39 AM
What welding machine are you using ?
Old 04-08-2012, 12:09 PM
I've see less bird poop in a dirty aviary!
Old 04-08-2012, 12:30 PM
aametalmaster aametalmaster is offline
Cool
Looks like some of the stuff i get in after someones cousins uncles grandsons neighbor welds on it first with their new HF 110V mig ...Bob
Bob Wright
Metal Master Fab
Salem, Ohio Birthplace of the Silver and Deming Drill.
http://www.ceilingtrains.com
Miller MM185 with 185 SpoolMate
Old 04-08-2012, 12:45 PM
H80N's Avatar
H80N H80N is offline
That Man Behind The Curtain
Yep.... lots of times they will try to use ER70-S6 wire in a Gas Less welder.... Pigeon Diarrhea.....
they are bad enough using the proper fluxcore................
Old 04-08-2012, 12:51 PM
Norm W's Avatar
Norm W Norm W is offline
Even a bad welder could have been a good grinder. He wasn't either one.
Old 04-08-2012, 01:13 PM
Is that item made from stainless?
_________________
Jennifer
My google+ page
DoALL 36"
Old 04-08-2012, 02:25 PM
Kind of sad, but its bucks in my pocket.
The welder is a V350 with the upgrade panel. It does some funny things. Its an awesome machine.
In the CV Plain ol mig mode, any time I select under 17 volts, it just welds at the voltage it thinks is best. So no I can't set it at 15 volts. It just welds where it wants too. It does it well.
In the CC stick soft or crisp mode when I turn the arc force to 10, it goes into CAC or gouge mode.
I had to call Lincoln when I first bought the machine. Both those items were left out of the instruction manual.
Nope its just plain ol carbon steel. I spent longer grinding than I did welding on this one.
I like the jobs that show up at my shop.
Old 04-08-2012, 03:27 PM
I'm surprised the guy didn't paint it.
That's what most craftsmen of that stature do. Make it look goooooood!
