Old 01-12-2012, 05:54 PM
Default Union Carbide Regulator/ Flowmeter :)
Few year back I had stumbled across a Union Carbide R502 2 stage flowmeter.. I really like it. Don't really know why it just makes sense to me. I like the selectable flowmeter..
Anyhow, I picked up the 2 stage on ebay and it needed a good cleaning.
then a few weeks later I picked up a single stage reg that you guys have seen in some of the pictures.
Turns out the regulator started life way back and is still produced by ESAB.
I ended up getting these 2 beauties for little money and they look about brand new.. I'm going to order a second stage spring spring and convert them into a 2 stage unit which new retails for between 400-550.00
I'll post up some pictures as I convert these to 2 stage unit to.
ID:	86252   Click image for larger version
ID:	86253   Click image for larger version
_________________
Jennifer
My google+ page
DoALL 36"
Old 01-13-2012, 09:56 AM
Floptop's Avatar
Floptop Floptop is offline
I'm looking and listening.
Old 01-25-2012, 09:28 AM
Few days back I took the regulator bodies apart and hooked them in series.
The check valves on both were leaking.
So, yesterday I ordered all the part need to rebuild them..
Turns out the rebuild parts are pretty inexpensive..
I ordered 2 sets to have one extra set on hand..
Like 28.00 for all the parts.
_________________
Jennifer
My google+ page
DoALL 36"
Old 01-26-2012, 08:49 AM
22-W's Avatar
22-W 22-W is offline
allessence,
I have a single stage regulator/flowmeter like the one you posted. It is labeled as a oxygen therapy unit. It is nothing that I will use. If you want it, you can have it. It looks perfect. I'm sure you could at least use the gauge, housings, etc.
Old 01-26-2012, 03:41 PM
Hi, Thanks.
If not as a welding regulator then maybe for my Oxygen kit for scuba diving.
I'll PM you my address and send you back a check for shipping.
thanks kindly Jennifer
_________________
Jennifer
My google+ page
DoALL 36"
Old 01-26-2012, 08:20 PM
monckywrench's Avatar
trust but verify
Who sold the rebuild kits? Now I know parts exist I may score a couple.
Feel free to post kit part numbers etc!
Old 01-26-2012, 08:42 PM
The Union Carbide "The Oxy-Acetylene Handbook" is one of my bedside readers (second edition, 1960). When they talk about "blowpipes", I have flashbacks to Tarzan movies and stuff.
Old 01-27-2012, 09:37 AM
trust but verify
Great book and recommended reading even for casual welders.
This one's on Ebay (not mine) for five bucks and shipping. Worth it for the torch porn alone!
Amazing how many of the them are still in production.
Old 01-27-2012, 11:41 AM
There are sellers at Abe Books listing the book from $3-$5, shipping included.
Old 01-27-2012, 12:06 PM
ESAB still sells this regulator. Or I should say the modern version.
New are very very expensive.
http://products.esabna.com/EN/home/g...eter_r502fm580
When I had received my first 2 stage one I contacted ESAB and they were kind enough to dig up the old manuals and faxed me a copy. There are actually 2 manuals plus other info..
the regulator was manufactured by Linde then sold as Union carbide, Linde and now ESAB.. Nice thing is it's been in production since like 1960 or something.
and in the 70's they raised the pressure from 20psi to 50psi. The raised the pressure to better cope with CO2 use.
Some would say this pressure is to high for good gas savings and that the 20psi version offers better shielding gas savings.
If one wanted to they could lower the pressure and calculate the flow rate for the given reading on the flow meter. My base model with stock spring screwed all the way out was right around 35psi.. So a lighter spring would offer lower pressure.
Anyhow, ESAB still has all the parts other than the ones they don't use for the current model, like the end caps.
These regulators on Ebay can be down right cheap. I just bout the 2 that really look like brand new for 51.00 and delivered for 64.80..
The rebuild parts are about another 20.00 for for the amount of money one can't go wrong.
Parts you have to order from an ESAB distributor.. in my case Airgas east.
Parts:
top gasket 77Z69 suggested retail 7.80 (2)
Oring 85W43 1.58 (2)
Diaphragm 30z58 3.19 (2)
1st stage spring 29Z54 5.34 (1)
2nd " " 29Z02 4.67 (1)
Filter inlet 71Z33 4.98 (1)
HP/LP seat 32Z60 0.09 (2)
Bottom cap 1st stage 71Z33 NLA
If you have the single unit (5007-5008 models) then you won't need the springs. Only if you are converting the single stage unit's to 2 stage do you need the new springs and a new 1st stage bottom cap. I haven't figured out the difference yet other then the 2nd stage unit has a screw for adjustment of pressure and the 1st stage does not.
Takes a true master to use a blowpipe. I've tried it but with little success. .
Seems like most of the welding books I've seen use vintage info. Even the book that came with Dyna was written years ago and didn't really have any new info for the inverter machine.
The Miller Student welder package is a great resource.
http://www.millerwelds.com/resources/tools/#training
Okay current price is 70.00.. When I bought mine 3 years ago it was 40.00 delivered.
_________________
Jennifer
My google+ page
DoALL 36"
