![]() Last edited by GWIZ; 04-27-2021 at 07:09 PM. Reason: rotate picture |
Take a look at my post in Off Topic "Pressure treated wood" .
...lew... |
TA Arcmaster 185 w/tig/stick kit MillerMatic 252 w/3rd gen 30A MM140 w/o AS, w/CO2 Hobart (Miller) 625 plasma Hobart 250ci plasma Victor O/A (always ready, but bored) TA 95 lunchbox w/tig 45ACP Black Talons for those stubborn jobs... |
My 2¢ is that anytime your replacing wood out-doors that you want to last for awhile, use pressure treated wood.
Let FAITH be bigger than your FEAR. ***** Pray like everything depends on God, and work like everything depends on you. ***** The world is changed by your example, not by your opinion. --St. Mother Teresa ***** In life it's important to know when to stop arguing with people and simply letting them be wrong. |
I haven't priced it out but I wonder if the composite decking might not be a better choice with the cost of lumber now days. When I redid my front porch I used Trex and it was @2x the cost of PT lumber. but that was back when lumber was cheap. As I said, I haven't priced it out lately.
Will probably use composite when I replace the decking have about 6 posts to replace and changing the rotten 2x8 across the front to a 2x10 or 2x12 most of the posts are 4x4 and rotted off at the ground going with 4x6 and putting them in about three feet of concrete deck is about 8 feet of the ground on the high end and about 4 foot on the short end. The deck is 28x10.
Chris One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors. Plato LET'S GO BRANDON!!!! |
Setting wood posts in concrete is a death sentence for them.
Use a form, pour your post, and put a post saddle in the concrete. Little more work, it’s the only way that I will set a structural post anymore. Code in many areas of Canada now too. Sent from my iPhone using Tapatalk |
