Old 07-07-2018, 04:35 PM
Default Yea!!
EPA head honcho Pruitt gave us a parting gift on the way out the door. You can still put together a truck that isn't an EPA Turd.
http://thehill.com/policy/energy-env...g-diesel-truck
Old 07-07-2018, 05:42 PM
Well , I guess gliders are still a business . Seems strange gliders are not held to same standard as the OEM .
Old 07-07-2018, 06:06 PM
Try driving any thing from Navicrap with one of their electronic DT's and you will understand why Mom and Pop's build gliders. Or any of the other POS that decide they need to REGEN when you need them the most. Gliders are a loophole that allow owner/operators a chance to survive. The door was set to pretty much close at the end of this year ( Thanks to O-Shitstain). I don't get to take advantage of this ruling as the Big Green 800 pound Gorilla is so proud of it's "Environmental Stewardship insert puking Emoji here. But, I'm still rooting for sanity and the little guy.
Old 07-07-2018, 06:14 PM
I know some small fleet operators here are looking at multiple gliders for replacing trucks.
Many of the ‘older’ engines end up getting better mileage doing the same job as newer trucks.
So, if they are using less fuel, thereby using less energy, isn’t that a good thing?
I’ve also heard a lot of horror stories of guys in new diesels being stranded because they’ve gone into limp mode due to emissions equipment. That’s been both in light (3/4 and 1 ton) and heavy trucks.
Old 07-07-2018, 06:41 PM
4x4ford 4x4ford is offline
Send a message via Yahoo to 4x4ford
I had a 2016 Pete 579 literally have the dpf filter which is basically a catalytic converter freeze with the truck running spent a week and a half in the shop over that
Old 07-07-2018, 06:44 PM
DDA52's Avatar
DDA52 DDA52 is offline
Blood, Sweat & Concrete
Great.....and I just leased a 2019 Pete.
Don
Old 07-07-2018, 06:52 PM
We have a rear load unit in the yard right now that got pawned off on us. Perfect for our market area. Small, agile packs pretty decent hasn't run a full 5 day week yet. The Cummins tech has been up 3 times . The theory at this point is we don't get it up to highway speed and run hard and hot long enough to keep it from wanting to REGEN like every third day. It's just an utter POS. It's 10 minutes from one side of town to the other @ probably 40 MPH not a lot of highway time if you know what I mean
Old 07-07-2018, 09:33 PM
I run otr and ran team at that time so the truck didn’t idle we were running close to 8000 miles most weeks in 5 days
Old 07-07-2018, 09:41 PM
This is a Glider.
What are you guys talking about??
...lew...
Name:	N341KG -Lew H compressed.jpg
Old 07-07-2018, 09:46 PM
Glider is a new frame and body that you get to install engine of your pick . They are installing pre tir 3 and 4 engines . Only real killer is they can't run California .
