  #51
Old 12-14-2021, 08:53 PM
Quill is about three bannans in diameter.
You bought CEE swag! Lol.
  #52
Old 12-15-2021, 05:55 AM
Edit
The big end of the taper in the spindle measures 1.345 inches. In the PDF GWIZ posted the measurement should be 1.310
I don't think its me. tell us what MT # and check your numbers again.
  #53
Old 12-15-2021, 06:18 AM
Thinking out loud ......
One option maybe a MT3 socket (or whatever they call them) with a straight shank.
plug welded in.
what I'm not sure is how hard the surface needs to be I'm thinking case hard.
so if you make a new spindle it will likely need to be hardened.
some of these sockets maybe hardened but it maybe hit or miss.
on the other hand if your old spindle ID is hard lathe tools may not cut it.
  #54
Old 12-15-2021, 06:52 AM
The chuck is a Jacobs 18N. I now have two of those in my tool cabinet.
Things have spun in the spindle a time or two. The chips are from when I drilled the back of the tang off.
Edit
I’m confused. There is no 1.310 on the Morse taper chart. Was it 1.2310 that you was measuring for MT#4?
Missed the 2? Probably phone keyboard error?Click image for larger version
  #55
Old 12-16-2021, 10:05 PM
OldRedFord's Avatar
Kibble King
Missed the 2? Probably phone keyboard error?Attachment 162873
1.2345 inches.
No case hardening on the spindle. Both the socket and outer surface cut easily with a file.
Tim
  #56
Old 12-18-2021, 12:18 PM
Chart shows dimension ‘A’ as 1.231”.
What’s the outside diameter of the section with the morse taper in it?
I’d be tempted to bore it out, then press in a ‘socket’ with a #3 or #4 taper in it. It would be cheap enough to buy and cut up a socket to use, avoids having to remake the entire piece, and will keep you reasonable ‘stock’ if that’s what you’re after.
Heck if you cut the socket off just at the slot for the drift your bore wouldn’t be as deep, and you won’t even have to line that up with the original when you press it in.
  #57
Old 12-18-2021, 07:52 PM
OldRedFord's Avatar
Kibble King
Been a full day on the road today.
ID:	162957   Click image for larger version
Tim
  #58
Old 12-18-2021, 08:33 PM
So where is the drilling head for that big radial arm drill press. I have one about that size at work. I think I’ve used it 8 times in the last four years.
  #59
Old 12-18-2021, 09:39 PM
OldRedFord's Avatar
Kibble King
Sitting on the floor of my shop. Along with other parts to the radial. Should be under the 4700 lb limit of my forklift.
Tim
  #60
Old 12-19-2021, 04:49 PM
OldRedFord's Avatar
Kibble King
Machines unloaded and safely on the ground.
Tim
