Does that make sense?
There are 10 types of people in the world, those who speak binary and those who don't. |
Bob, you need to look at the drawings again and read post # 4
It's not a good idea to parallel bridges especially if they are not the same.
* * The factory of the future will have only two employees, a man and a dog. The man will be there to feed the dog. The dog will be there to keep the man from touching the equipment. ~Warren G. Bennis Last edited by GWIZ; 07-20-2010 at 02:31 PM. |
No, not to me, why change from the original, just because of a switch change ? It seems odd to me that the power supply is fed with an ever changing voltage, unless they are using it to make changes to the drive motor speed (independent of the rheostat setting) based on how low the arc pulls the transformer voltage down. (and wether or not you are set in hi or low voltage) |
There is a few options but here is what you wanted.
Here is the added relay BUT depending on where the power taps for reversing the polarity are located the added relay will have to be located at the down stream side of the taps.
![]() As to paralleling the bridges, GWIZ, you are correct if both circuits are in use at the same time. I had believed that Hobby was interested in adding a second gun (something I apparently misread or dreamed up). In that case either bridge one OR bridge two would be in circuit, never both at once. Hobby I think you need to take a dvm and go through the circuit paying attention to the voltage on the wirefeed controller input with and without the extra capacitor. I think you're fooling it to believe that the wirefeed pot has been turned up on the front panel. a series trimpot should take care of it. I'm not sure I understand why you want the extra cap in the original welding circuit Hobby? I'm pretty sure the welding engineers put in the correct value at the factory. That cap DOES smooth the DC but it also changes the rise and fall times in the circuit and may mess with your weld beads. As I recall the traditional circuit element to add was an inductor, not a capacitor. I think I'll quit now before I get in any more trouble. DrBob |
Thanks, this unit is shielded gas only no reversing taps. Ken
I appreciate the added input. The main reason was to get a little more punch to help wet out the puddle better. Pic 1 from this..... Pic 2 to this.
Per my old linde mig supply:
1. Wetting is more inductance. Not neccesisarily affecting current (or wire speed). 2. More voltage is more "punch" (total heat input), up it and you need to increase wire speed as well. EDIT: your only going to get so much from a wall socket. If this is a 220 vac unit, your only gonna get so much thru that (transformer) core. |
It's ok to tap off the AC side and feed a second bridge, but in your drawing the minus sides are connected to both bridges. You can not connect the plus or the minus sides of one bridge to the other.
