Old 12-03-2019, 10:23 AM
The reducer is a 90 degree with a .5" input and a 7/8" out put shaft and a 65.5 to one ratio. Guessing about 30#
Old 12-04-2019, 07:14 AM
gimpyrobb's Avatar
So the wheel I've got is about 18 across and has a bore of about 7/8. The surface the belt would ride on is about an inch wide and flat but is aluminum so you could machine a lip on it pretty easily if you have the swing capacity.
Old 12-04-2019, 07:54 AM
"Score" ???
You still have to heave the ingredients up in there.....
Should have gotten one with some minions...or a lift...
ID:	153310   Click image for larger version
ID:	153311   Click image for larger version
Old 12-04-2019, 10:13 AM
"Score" ???
His is still a step above a wheelbarrow and a hoe. Gotta take the scores when you can. And still leave room for more improvements.
Old 12-04-2019, 01:01 PM
RED caddy's Avatar
Da Chief
Good score, nice repair, fer my nickel, I'd leave the shaft as is, just use a different part of the shaft threads. Add spacers or cut a new, longer nut. (Yea I'm gettin' lazy in my old age...
RED
