Old 05-18-2021, 03:34 PM
Default woodruff key
What RPM for a 3/16 by .75 did cutter on a .75" shaft that has been built up and turned? Its a #606?
Old 05-18-2021, 04:20 PM
You have to go by the amount of teeth that are on the cutter. ? ? ?
Assuming you are cutting steel and its on a small mill about 100 rpm's would be a starting range.
and a-lot of dark cutting oil.
Old 05-18-2021, 04:30 PM
12 teeth and a big mill
Old 05-18-2021, 04:39 PM
then 200 rpm on the safe side.
be sure to lock down the quill, its the start that can pull or pushup the quill.
Old 06-11-2021, 02:35 AM
Nehab08 Nehab08 is offline
I'm using Grizzly G0555, Its a good to work with wood and metal, Mostly I'm doing for wood. It contains Dual voltage system and 1500fpm and 3200fpm.
Old 06-11-2021, 06:30 AM
Spam here often ?
If your going to post, at least try and answer the OP's question.
