Old 02-14-2020, 09:36 PM
threepiece threepiece is online now
Default Fuji Electric Motor Brake with Smoke
I got two of these gear motors from the scrap yard recently. Although the motors run smoothly I noticed smoke exuding from the rear where the brake unit is after running for about one minute. It also got quite hot in that area only. I tried the other motor and noticed heat building up the same after about 30 seconds so I disconnected it.
I tried to remove the fan shroud (TEFC) that is covering the brake area but there are two pins protruding through the cover that rotate about 90 degrees preventing it from coming off. The pins had a wire rod connecting them together and a retaining clip to keep the assembly secure.
Can someone shed some light on this? I don’t think I will be wanting the brake, can I disconnect it so it doesn’t smoke? How can I remove the shroud?
Thank you all for any help.
Old 02-14-2020, 09:51 PM
Expect the brake function is on when power is off. Must not be getting power or is burnt out. Have no idea as to disassembly.
Woodrow Wilson
Old 02-15-2020, 10:44 AM
Scotts Scotts is offline
I have not had hands on with this particular type, however most have a way to manually disengage the brake so you can turn the motor with no power on.
On the picture you attached it shows the wire bail turned to disengage the brake. There is a protrusion sticking out the outer circumference of the brake in the picture, I have a feeling that the wire needs to go back in place and flip it over to disengage the brake, tie it up and the brake should be held in the off position.
Also there is a gap specification for clearance on the friction elements, there is probably an access hole to adjust this, just open it up all the way and you should be good to go.
The brake may have a setscrew on the shaft holding it to the motor shaft.
The coils on the brakes are all over the place as far as voltage, ac or dc ya never know without the book.
Old 02-15-2020, 03:24 PM
Yes, you are right. I reinstalled the wire/rod, flipped it up and tried running it again. This time there was no smoke or heat.
I’ll post another picture later.
Old 02-15-2020, 08:58 PM
I found an access hole under two rubber plugs. Looking in I can see the friction plates but no means to adjust. I can clearly see movement in the plates when the control arm is moved.
The ratio of the gear box is 30:1 but I can still manage to turn it by hand with the brake arm up/released, I cannot with the brake lever down.
Thanks a bunch!
Attachment 154816
Old 02-15-2020, 09:01 PM
Nice find. What are you going to power with them?
Old 02-15-2020, 10:12 PM
You’re welcome
I did not find a manual for the brake to see how it all come off or gets installed. I did not get to find good info on Fuji website.
Those shafts look like they have to come out to get the cover off.
Old 02-15-2020, 11:14 PM
I will be needing help processing firewood soon enough. A splitter is in my thoughts but I have a different plan for this gear motor.
Wood that is too small to stay in place when a chainsaw is applied is troublesome to me. I wish to make a shear or lopper to cut wood up to 4” diameter.
Old 02-15-2020, 11:19 PM
You’re welcome
Thanks again for your effort but I don’t see a need to consider this further. I will simply secure the arm up and run it. I’m concerned that I may find the brake is somehow integrated with the cooling system and should not be removed so no need to take the shroud off.
