Old 10-21-2018, 04:41 AM
not enoughsmoke not enoughsmoke is offline
WOW nice shop it should take some time to fill it up
Thanks I have been Trying not to fill it up so fast but the deals kept comming
Originally Posted by Whitetrash View Post
I give it 3 Months give or take before you'll have to pick a path to thread through it. I've seen it many times the shop Gremlins that come out at night will consider it a challenge.
Close but i try to keep thinks organized too
My craftsman took a dump so i upgraded to a IR
and ran across a engine parts washer for a steal
ID:	147665   Click image for larger version
ID:	147666   Click image for larger version
ID:	147667   Click image for larger version
ID:	147668   Click image for larger version
Old 10-21-2018, 07:50 AM
To move all the Diesel Trucks i work on around the shop as well as other things I got a Case 586c. Then start putting up sheet metal on the walls.
ID:	147670   Click image for larger version
ID:	147671   Click image for larger version
ID:	147672   Click image for larger version
ID:	147673   Click image for larger version
Old 10-21-2018, 07:59 AM
Did some painting around my doors to blend everything in and trimmed out the walk in door
my son was very patient and helpful Not with the painting thou He was not around the paint part lol
ID:	147675   Click image for larger version
ID:	147676   Click image for larger version
ID:	147677   Click image for larger version
ID:	147678   Click image for larger version
Old 10-21-2018, 08:02 AM
Got Me some wall Decorations and new miller Tig machine
ID:	147680   Click image for larger version
ID:	147681   Click image for larger version
ID:	147682   Click image for larger version
ID:	147683   Click image for larger version
Old 10-21-2018, 08:07 AM
Finally Found a Old Bridgeport J head milling machine soled the small lil Chinese one i had. Now i can finally do some work on a decent milling machine
here are also some pics of a Cummins cylinder head i milled off the intake for my pull truck
and some lathe and turbo work with my new Tig machine
ID:	147685   Click image for larger version
ID:	147686   Click image for larger version
ID:	147687   Click image for larger version
ID:	147688   Click image for larger version
Old 10-21-2018, 08:10 AM
The back of the Shop when I decided to remove the 4 6x6 post that i have never used
ID:	147690   Click image for larger version
ID:	147691   Click image for larger version
ID:	147692   Click image for larger version
ID:	147693   Click image for larger version
Old 10-21-2018, 08:11 AM
Concrete guys preparation for new slab
ID:	147695   Click image for larger version
ID:	147696   Click image for larger version
ID:	147697   Click image for larger version
ID:	147698   Click image for larger version
Old 10-21-2018, 08:14 AM
And the pad is poured 30x72
ID:	147700   Click image for larger version
ID:	147701   Click image for larger version
ID:	147702   Click image for larger version
ID:	147703   Click image for larger version
Old 10-21-2018, 08:18 AM
More pics of the pad i also had him pour around the sides to keep out Critters and water
ID:	147705   Click image for larger version
ID:	147706   Click image for larger version
ID:	147707   Click image for larger version
ID:	147708   Click image for larger version
Old 10-21-2018, 08:34 AM
built my son a gravel pit, playing on the lathe,and hung my ford sign
ID:	147710   Click image for larger version
ID:	147711   Click image for larger version
ID:	147712   Click image for larger version
