Old 10-17-2018, 04:46 AM
not enoughsmoke not enoughsmoke is offline
Default Machine/Mechanic/weld shop
As Some may have noticed my shop on the aluminum car hauler build.
My shop has had a transfomation like the semi trailer to car hauler
the building was a 24x48 divided into 3 sections
1. equipment
2. dog house
3. horse stable
here she is when i started
Name:	IMAG0426 2_zpsnn9gns7e.jpg
ID:	147511   Click image for larger version
ID:	147512   Click image for larger version
ID:	147513   Click image for larger version
ID:	147514   Click image for larger version
Old 10-17-2018, 04:49 AM
here are some more the concreted pad outside and inside is the dog house notice the holes in the wall
Name:	IMAG0428 2_zps8vr5gvky.jpg
ID:	147518   Click image for larger version
ID:	147519   Click image for larger version
Old 10-17-2018, 08:30 AM
alchemist's Avatar
Do you raise dogs or are they just pets?
Old 10-17-2018, 10:44 AM
no this was on the property behind the house i bought it. The original owners built this when they built the house.
Old 10-17-2018, 11:46 PM
I tore the wall out and installed a garage door to have better access to the 1 concreted floor in the shed
And did some painting
ID:	147552   Click image for larger version
ID:	147553   Click image for larger version
ID:	147554   Click image for larger version
ID:	147555   Click image for larger version
Old 10-18-2018, 01:38 AM
installed my Craftsman air compressor in the top of the shop and plumb my air lines with PVC (yes i know not a wise choice)
added the post out front to install i beams on to pull truck cabs and beds
on the end i installed a shed from my previous house that match damn near perfect to the shop
ID:	147557   Click image for larger version
ID:	147558   Click image for larger version
ID:	147559   Click image for larger version
ID:	147560   Click image for larger version
Old 10-18-2018, 01:41 AM
I then Installed 2 10" Z purlins to remove the center post of the shop
then Started walling up the end of the shop
With some free Sheet metal
ID:	147562   Click image for larger version
ID:	147563   Click image for larger version
ID:	147564   Click image for larger version
ID:	147565   Click image for larger version
Old 10-19-2018, 11:58 PM
Pressure washed the Free Sheet Metal
Removed the old Barn Door for a conventional Shop walk in door
ID:	147590   Click image for larger version
ID:	147591   Click image for larger version
ID:	147592   Click image for larger version
ID:	147593   Click image for larger version
Old 10-20-2018, 12:01 AM
Then had the Floor Poured
ID:	147595   Click image for larger version
ID:	147596   Click image for larger version
ID:	147597   Click image for larger version
ID:	147598   Click image for larger version
Old 10-20-2018, 12:08 AM
They Cam back and Cut the next day
ID:	147600   Click image for larger version
ID:	147601   Click image for larger version
ID:	147602   Click image for larger version
