Old 11-06-2011, 09:58 PM
NCMau NCMau is offline
Default Air Compressor Problem
I have a 2HP Craftsman shop compressor. Sometimes when the tank pressure reaches the low level, it tries to start and the motor overload kicks in. I changed the motor… didn't help, replaced the new check valve, didn't help either.The compressor head has a petcock which, I guess, eliminates the back pressure at restart. The petcock is open and it does what it supposed to do.
Unless there is something screwy internally, I have no clues on this problem. As I said, it doesn't do it all the time, but when it does, I have move the flywheel, then it starts again. Any suggestions would be welcome.
Old 11-06-2011, 10:43 PM
H80N's Avatar
H80N H80N is offline
That Man Behind The Curtain
if it is the old speedair style... you probably have a gummed up unloader.... take a pic of the pump and post it so we can see....
Old 11-07-2011, 03:16 PM
Jim-TX's Avatar
Jim-TX Jim-TX is offline
Chairman of the Headboard
Are you running it on an extension cord? A compressor takes a lot of juice to get started. They won't work on a small cord.
Jim
Old 11-07-2011, 05:19 PM
digr digr is online now
Are you using 220 or 110 volts to the motor?
Old 11-09-2011, 09:39 AM
To answer your questions:
The compressor is wired for 220V plugged to the wall and the proper voltage is available.
If I have to check the unloader, will it be accessible when the head is removed?
I have taken engines apart, but not compressor heads.
ID:	83754   Click image for larger version
Old 11-09-2011, 11:00 AM
H80N's Avatar
Default Sears-enstein 2HP
Right now you have NO Unloader!!! somebody removed it.... no wonder it overloads and locks up...
From what I can see..... you have what may have been a Craftsman compressor at one time.... looks like the tank might be original......but not much else..
What you now have is a Frankenstein Mfg Co. Special....
where the unloader tube would have been on the head of the original pump... somebody put an automotive style radiator petcock...(on a similar but replacement pump). the unloader tube WOULD have gone down to a combination pressure switch/unloader..... which is now long gone.... looks like some crafty devil found a home water pump pressure switch at the hardware store and wired that in (unfortunately it has no unloader feature)
Here is a link to a similar (but 1hp Sears compressor) look for part #75 on the diagram
http://www.searspartsdirect.com/part...&prst=&shdMod=
and here is a link to the combination switch/unloader
http://www.searspartsdirect.com/part...PRESSOR&blt=11
switch is $84... by the time you are done it will be well over $100 plus your time... is it worth it to you?? I have a similar 1hp Sears that will be dedicated to plasma cutter duty... that I can photograph and post if you want to see what the unloader/switch looks like installed...
Old 11-09-2011, 11:57 AM
H80N's Avatar
Default unloader/switch
Here are a couple of pics to illustrate
#1 shows combination switch/unloader with tube coming down from compressor head.
#2 Shows unloader tube coming off of the compressor head (small aluminum tube where yours has the petcock)
Name:	compressor 003-c.jpg
ID:	83756   Click image for larger version
Name:	compressor 004-c.jpg
Old 11-10-2011, 08:17 AM
Default Compressor Problem
Thanks for the info, H80N. I think the only Craftsman components of this compressor are the motor and the pump. When I bought it, it didn't have the a pressure switch, so I installed what I had in the shop, being ignorant about the unloader feature.
$100 for a Craftsman switch would not be worth for me to invest on this machine. I found couple reasonably priced combo units on bay. Do you have suggestions on the two? It looks like both of them would work.
Again thanks for the help.
http://www.ebay.com/itm/NEW-PRESSURE...ht_2102wt_1011
http://www.ebay.com/itm/Air-Compress...ht_2033wt_1011
Old 11-10-2011, 09:20 AM
H80N's Avatar
Since they seem to be identical in all other respects, even price if you factor in shipping... I would go with the 4 port just for convenience sake... just in case you want to install a pressure guage or reg there with it.... , worst case you install some brass pipe plugs in the unused outlets...
"NEW PRESSURE CONTROL SWITCH VALVE FOR AIR COMPRESSOR 95-125 4PORT W/ UNLOADER L4"
keep us posted...
Just as a side note... looks from your pics that this pump uses the heavy felt intake filter..... that is something that people usually neglect... they will clog and greatly reduce the capacity of the compressor.... it will work its heart out with lots of noise and heat but not produce much air.... they will get super clogged in a minute if they are around spray painting.(paint your car??)... Many people will take them out and replace with the oiled open cell foam that is used for lawnmower engines.... (hardware store or home center $3 cut to fit)
Second side note.... make sure you have enough clean oil in the pump... You would be amazed at how many people never even check it, let alone change it (I run Mobil1 Synthetic, with good results... others may disagree)
Old 11-11-2011, 01:07 PM
4 Ports switch on order. Notes are noted and will post results.
