Old 01-10-2019, 11:19 PM
For that application any plastic will do. Delrin, UHMW, nylon; you name it; there isn't enough load that you'd be able to tell the difference...
Keith...
I'm just going by the two different color Delrin which one should I use as that is the only material I have available to use for this...
and if one is better than the other and need not be wasted I'd rather not waste any of one or the other but it is still all I have to work with...
Old 01-11-2019, 02:31 AM
Keith...
Without some way of tracing the origin there's no way to know if there is a physical difference between them. When it comes to colours there is no standardization between manufacturers so colour is no indication of the specific grade of material. They could be identical materials or they could be completely different. There is always a possibility that they are not even Delrin because, even though it is a brand name, it has become very generic and can mean different things to different people. In your case use whichever you want because it won't make a difference.
One thought. If one of the pieces is natural colour it's more likely to be a lesser grade than one that's coloured but that's a guess only...
Old 01-11-2019, 03:33 AM
Kieth have you tried freezing the umhm before machining . We used to freeze before machining or drilling .It helped but thawed fast .
Old 01-11-2019, 04:20 AM
Originally Posted by midmosandblasting View Post
...Kieth have you tried freezing the umhm before machining...
I've never tried it but I've never felt the need to either. If you use really sharp tooling and take fairly heavy cuts UHMW doesn't machine that bad; you just have to deal with the really stringy swarf that the cut produces. I use the ultra-sharp uncoated inserts designed for aluminum--they cut really well and leave a good surface finish, especially if you take a heavy DOC and spin the RPM up good...
Old 01-11-2019, 06:39 PM
My experience with Delrin...
Keep it out of a tankhouse environment. Sulfuric acid will eat that stuff alive. Guess you don't really have to worry about that, tho.
Delrin is great for stable low friction applications. It won't creep like PTFE will.
You Suck...
