Old 01-06-2019, 12:55 PM
Is the center pin a press fit?
Yes it is press fit... It just barely stuck un by the taper just for show partial assembly just to show what I have of it so far...
I still need to tap the 1/4.20 threads counter sink the screw for the indicators..... run it through the championing machine, then for the final back to the mill drill for dressing it up after all that then ill press fit the center shaft.
But no time to work on it today I have to go to work and sometimes it takes me out and away from the shop mobile call to fix a distressed dodge ram 3500 and then work on his IH tractor while I'm there...
Bad part is I don't have much Getty up and Go today.... No energy but not much choice in the matter so gotz ta go..
Old 01-06-2019, 12:57 PM
I used to use a brake rotor but the grooves in it from the worn out pads made it pretty finicky. I copied Kieth's edge tool in about 30 minutes and love it.
I have several loose indicators that I can use including one .0001 precision now if I only had two of them I could dial it in closer than Rons paint
Old 01-06-2019, 05:17 PM
What about using a new rotor woner if it will be more presice than a used rotor and would it be worthhaving it presion ground to be accurate
Well got to get back to work brake is over
Old 01-06-2019, 05:51 PM
For certain it will I was just rattling chains there is no way you can use a used rotor for tramming a mill.
Old 01-06-2019, 10:30 PM
Ok so its taking me a bit longer to get this thing made cause my turning tools are shit! either dull or chipped and I have not learned to grind my own to well just yet so have to use the HF turning tools that are not quite sharp so its slow going…. but so far so good here is what I have now and how far it is but have a few other things to do before they are finished and am still working on the first one...…
Attachment 148729Attachment 148731
Looking damned good to me.
Harry S. Truman
Old 01-06-2019, 10:39 PM
Well you had me wondering and trying to figure out how it would work
cause hindsight tells me most any used rotor is going to be either warped or slightly warped if not chewed up by the pads with groves......
Thanks' Chris....
Old 01-15-2019, 12:27 AM
Ok I had some anxiety issues today had planned on just relaxing all day but just couldn't sit still so I got up and piddled a little bit with the Spindle Squares
One, I will have to start from scratch because I made some bad mistakes.
I made a few mistakes on this one as well And might just need to start over on this one also... Although it will only just affects the way it looks, And not the wait it will work...
So please don't laugh too hard...... I Think I might have been able to do a better job on my drill press. I'm not fond of this Mill drill at all can't wait to get at least one of the bigger mills in and up an running...
The only way I'm going to learn to do some of this stuff is by making mistakes.... and I sure made a few tonight
Anyway here is The mess I made of it... I still need to press the shaft in and tap the threads for the locking screws... and do some deburring and clean up so this one might not look too awfully bad but not anywhere' near how it should look...
ID:	148822Click image for larger version
ID:	148823Click image for larger version
Old 01-15-2019, 02:19 AM
Why do you want to tram a drill press?
Just want to level my drill press tables because they are not correct on the Zeroing scale and noticed the holes when I drill through thick metal for bolts I end up having to enlarge the hole so that the bolt will line up... So I figure if I tram my tables, I won't have to enlarge the holes any more an I"ll get a better fitment on what I'm working with at the time... I believe it will make for less Stress on my bits an a bit less work for me in the end.
It's really the only reason for it, Is all...
Old 01-15-2019, 03:42 AM
If it is the surface finish you think is ugly , sand blast it and they will blend in .
Old 01-15-2019, 11:35 AM
I was thinking I have three options for that...
One being I could debur it by hand and then buff and polish on the wheel
Two I could Sand Blast it to blend it and have then sort of satin finish...
Three I could put it no the vibratory polisher but I am not sure of what the finish would come out to, because of its one of those tools I've bought and got two of that I have not used yet since I bought them...
So those are my three choices of getting a finish on it... not that that is so important for it to function correctly
