Old 01-09-2019, 12:09 AM
My mill does not have a reverse switch. My neighbor Walter looked it over and it is capable of reverse. Took of the motor cover and there is instructions for reversing, so add a box, switch and some jumper wires and then I can tap using the mill. Did a quick test swapping wires 5 &6 and it runs in reverse. Get to this on Friday after we get back from her surgery in CO.
Is your variable speed or do you have to change speeds like my mill drill ?
Old 01-09-2019, 06:52 AM
Mine is a belt drive, so change belts from pulley to pulley.
Old 01-09-2019, 10:29 AM
Yep mine is to. It will prolly temporarily go live elsewhere along with the welding table and two or three of my seven drill presses...
so I can make enough room for two mills and another lathe
although I am kicking around the idea of gathering enough steel to have another small building built something 20 by 20 just to house the machining equipment but outlook is some stuff will just have to live at a buddy's place indefinitely till I can ad on or build a separate building most likely smarter thing would be just to ad on..
Old 01-10-2019, 10:34 AM
Always good to keep machining equipment and welding and grinding tools away for machining equipment.
Old 01-10-2019, 11:49 AM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Weld smoke and grinding dust are hell on machine tools.
A friend over in Ohio bought a 40' high cube refrigerated sea can, had a bad cooling unit, used it for his shop and office until wife inherited her grandma's place. He was going to move it for storage, but the people who bought their old place wanted it left there.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 01-10-2019, 04:16 PM
I now have a forward/reverse switch which is real handy for power tapping. The neighbor Walter did all the wiring for me. Not my specialty. Tapped a couple 3/8-16 holes in the mounting plate. Works great. 33 more holes to tap.
Next add wire in the LED halo light so a blind guy can see what he is doing. Also gotta get a couple of the HF link belts to replace the bad ones on the mill.
ID:	148768   Click image for larger version
ID:	148769   Click image for larger version
ID:	148770   Click image for larger version
Old 01-10-2019, 05:06 PM
That will work.....
Old 01-10-2019, 07:51 PM
Got 20 done today. The other 20 tomorrow.
