Old 12-30-2018, 11:59 PM
Default Mill Mounting Plate
Started making a mounting plate for the mill today. It is a 1/2" plate and will have several tapped holes with 3/8-16. Also have four 1/2-13 holes to bolt to the table T nuts. Today I ran a 2" facing cutter to get a flat smooth surface on the plate. Came our real well. The hole layout will be tomorrow.
Woodrow Wilson
Old 12-31-2018, 09:52 AM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Chris, dye the surface or use a sharpie to lay out the hole pattern, this will give you a visual reference to the hole locations while you are moving location on the plate.
Add a secondary pattern of 1/4" - 20 tapped holes.
Most work I have done on a plate is light machining, so it is handy to have smaller clamping accessories at times.
Once you lay out the 3/8" pattern, drill it before laying out the smaller 1/4" pattern or use a different color sharpie to mark them. Drilling many holes of two seperate sizes can and does get confusing.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 12-31-2018, 11:10 AM
Once you lay out the 3/8" pattern, drill it before laying out the smaller 1/4" pattern or use a different color sharpie to mark them. Drilling many holes of two separate sizes can and does get confusing.
Dan.
Already put on Dykem on the plate. I will only have four 1/2" holes to mount to the table. Will use flat allen head 1/2" screws to attach to the table 1/2" T nuts. I do need to get a set of 3/8" studs and clamps. I could get some 3/8" T nuts, then I would not need the 1/2" holes. Decisions, decisions, decisions.
Woodrow Wilson
Old 12-31-2018, 02:16 PM
greywynd greywynd is online now
Smaller clamps can also be made. I have some as small as 5mm.
With smaller clamping setups, the height should be kept to a minimum, so socket head cap screws or hex head bolts can often be used instead of studs.
Old 12-31-2018, 03:08 PM
Cap screws! Another good idea. Thanks.
Woodrow Wilson
Old 12-31-2018, 05:17 PM
Just make sure to use decent washers. I used to have sources for heavy (williams was what we called them) washers that worked really well for clamping applications.
Old 12-31-2018, 05:24 PM
I have lots of good washers.
Woodrow Wilson
Old 01-01-2019, 09:28 PM
Too cold for shop work yesterday. Did get the four 1/2" holes laid out and drilled today. I will get the countersinks done tomorrow. Probably lay out the 3/8" tapped holes too.
Woodrow Wilson
Old 01-02-2019, 07:26 AM
Well Chris... I cant wait to see the final product, well, I mean I have to wait but I am, looking forward to seeing it once you finish the mounting plate
Old 01-02-2019, 12:09 PM
I use a standard pitch of 2.5" or a multiple of 2.5" for all my fixtures in my shop. The 2.5" is derived from the T slot spacing on my milling machine. This allows me to use fixtures on all four of my fabricating tables which also have the same pitch and thread.
